Found this N the Trans Pan. Is this a real bad thing?
#19224
11/28/05 10:20 AM
11/28/05 10:20 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
When working on the stripped trans pan bolt in the 65 Barracuda, I found this clip in the bottom of the transmission pan. Does anyone know where it might go and how bad a thing might this be?
Thanks, Joe
65 Barracuda 70 Challenger
Re: Found this N the Trans Pan. Is this a real bad thing?
[Re: dartman366]
#19227
11/28/05 12:21 PM
11/28/05 12:21 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks for taking a look and giving me your thoughts. I will take a look and see if I can figure out where it goes and if it is an "extra" or not.
Thanks again.
Joe
[Re: dartman366]
#19228
11/28/05 12:27 PM
11/28/05 12:27 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
that's about the only thing that I can think of that uses a clip like that.
Theres a good chance thats what it goes too.
Good luck w/the trans
[Re: 6o4o]
#19230
11/28/05 01:13 PM
11/28/05 01:13 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
The governor also uses this type of clips, but I don't know if that could get into the oil pan from the output shaft...
good point but it looks bigger than a govenor one ???
[Re: JohnRR]
#19232
11/28/05 01:19 PM
11/28/05 01:19 PM
dartman366
Mt. Vernon, Ohio
comparing the size of the clip to the hand that's holding it, I would say parking rod clip, unless he has really, really small hand's, the one on the govenor is quite a bit smaller than that one, I believe the stem thru the govenor is approx. 1/8 dia.
[Re: jrwoodjoe]
#19233
11/28/05 06:32 PM
11/28/05 06:32 PM
that should be a cable tranny. i'm betting the c-clip fits the little cable connector that attaches to the valve body. cable tranny's don't have the park rod that runs up to the valve body. page john kunkel, he'll know!
#19234
11/28/05 11:19 PM
11/28/05 11:19 PM
Doesnt the governor use an internal snap ring? I would say park rod also but im not familiar with the pushbutton trannys.
#19235
11/29/05 09:41 AM
11/29/05 09:41 AM
there isn't any park connection inside the main case of a push button trans. i've taken those little c-clips off before on my 65 trans.
#19236
11/29/05 10:05 AM
11/29/05 10:05 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks for the advice. This is not a push button tranny. It is floor shift.
Joe
[Re: jrwoodjoe]
#19237
11/29/05 10:55 AM
11/29/05 10:55 AM
i think the only difference on a 65 floor shift tranny vs a push button is the rooster comb for the gear selector at the valve body. if its a 65 trans then its probably the c-clip for the cable connector.
[Re: jrwoodjoe]
#19238
11/29/05 04:12 PM
11/29/05 04:12 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Common e-clips: Left is the '64-'65 shift cable adapter which is .025" thick Second from left is the governor which is .042" thick Second from right is the external throttle shaft Far right is the '66-on Park rod.
[Re: John_Kunkel]
#19242
11/30/05 05:13 PM
11/30/05 05:13 PM
john, your title needs to be changed from "master" to "master tranny man".
