Which Engine oil for my 426 Hemi
#1921225
09/28/15 03:17 PM
09/28/15 03:17 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Ok, I resealed the heads and now no leaks. I used brad penn break-in oil and its time to change that. I have ten quarts of mobil 1 15w-50 synthetic from a friend to use, or what I normally use is Valvoline VR1 20W-50 racing oil. Which should I use or does it matter. I prefer to stay with the Valvoline though. The engine will see track time. Thanks.
RS23L7 4-Speed
Re: Which Engine oil for my 426 Hemi
[Re: Mopar_Mike]
#1921314
09/28/15 05:35 PM
09/28/15 05:35 PM
Posts: 5,163 CT
GTX MATT
CT
I would use the VR1. If you use the Mobil 1 I would add a zinc additive. Or Brad Penn is a good choice as noted above.
[Re: Mopar_Mike]
#1921326
09/28/15 05:52 PM
09/28/15 05:52 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
If this is a new engine do not use the Mobil one till you have at least 5k miles on it.
Go to napa and get some 10-40 VR1 , the 20 50 is too heavy and not needed.
[Re: Mopar_Mike]
#1921688
09/29/15 10:17 AM
09/29/15 10:17 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I've used Mobil One 15w50 in my street/strip hemi since I built it...well, after the break in period was done. I like the VR1 Valvoline also.
[Re: Mopar_Mike]
#1921707
09/29/15 11:12 AM
09/29/15 11:12 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Rotella 15/40 is what I use.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: an8sec70cuda]
#1921831
09/29/15 03:18 PM
09/29/15 03:18 PM
JohnRR
U.S.S.A.
I've used Mobil One 15w50 in my street/strip hemi since I built it...well, after the break in period was done. I like the VR1 Valvoline also. Chip, what was your break in period , Dan Costello is the one that told me about going 5k first.
[Re: Mopar_Mike]
#1921839
09/29/15 03:26 PM
09/29/15 03:26 PM
an8sec70cuda
I start w/ the conventional VR1 Valvoline oil. Ran it for about 20 minutes or so in the shop and easing down the driveway (my driveway is 1/4 mile long), then changed the oil and filter (more VR1 conventional). Then ran it once at the track and put maybe 50 HARD street miles on it before I put synthetic in it. I drive the snot out of em from the get go.
