Which Engine oil for my 426 Hemi
#1921225
09/28/15 03:17 PM
09/28/15 03:17 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Ok, I resealed the heads and now no leaks. I used brad penn break-in oil and its time to change that. I have ten quarts of mobil 1 15w-50 synthetic from a friend to use, or what I normally use is Valvoline VR1 20W-50 racing oil. Which should I use or does it matter. I prefer to stay with the Valvoline though. The engine will see track time. Thanks.
RS23L7 4-Speed
Re: Which Engine oil for my 426 Hemi
[Re: Mopar_Mike]
#1921314
09/28/15 05:35 PM
09/28/15 05:35 PM
Posts: 5,173 CT
GTX MATT
CT
I would use the VR1. If you use the Mobil 1 I would add a zinc additive. Or Brad Penn is a good choice as noted above.
[Re: Mopar_Mike]
#1921326
09/28/15 05:52 PM
09/28/15 05:52 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
If this is a new engine do not use the Mobil one till you have at least 5k miles on it.
Go to napa and get some 10-40 VR1 , the 20 50 is too heavy and not needed.
Mainstream Media is the new Pravda
[Re: Mopar_Mike]
#1921688
09/29/15 10:17 AM
09/29/15 10:17 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I've used Mobil One 15w50 in my street/strip hemi since I built it...well, after the break in period was done. I like the VR1 Valvoline also.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Mopar_Mike]
#1921707
09/29/15 11:12 AM
09/29/15 11:12 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Rotella 15/40 is what I use.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: an8sec70cuda]
#1921831
09/29/15 03:18 PM
09/29/15 03:18 PM
JohnRR
A gulag near you.
I've used Mobil One 15w50 in my street/strip hemi since I built it...well, after the break in period was done. I like the VR1 Valvoline also. Chip, what was your break in period , Dan Costello is the one that told me about going 5k first.
[Re: Mopar_Mike]
#1921839
09/29/15 03:26 PM
09/29/15 03:26 PM
an8sec70cuda
I start w/ the conventional VR1 Valvoline oil. Ran it for about 20 minutes or so in the shop and easing down the driveway (my driveway is 1/4 mile long), then changed the oil and filter (more VR1 conventional). Then ran it once at the track and put maybe 50 HARD street miles on it before I put synthetic in it. I drive the snot out of em from the get go.
