Re: Hellcat transmission and big-block engine
[Re: paddel]
#1918186
09/23/15 05:05 PM
09/23/15 05:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Anything can be made to fit anything else. But it'll boil down to how talented you are, or your friends, to make it work.
I watched a guy build a Yugo with a 460 in it. Pretty sure the 460 weighed more than a stock Yugo did. But he built it right, caged, reinforced, etc.
[Re: paddel]
#1918213
09/23/15 05:41 PM
09/23/15 05:41 PM
Posts: 107 germany
paddel
germany
i am an electric engineer. the floor wouldn't be a problem. I have a 74 newport. isn't the torsion bar crossmember wide enough? I think that would be the biggest problem for me. some time ago I read that some guys already put modern transmissions behind big blocks. As far as I know modern transmissions have computers for themselves and are not (or not totally) hooked up to the ECU. I'd really like to make this happen. Of course there would be more intelligent solutions. keeping the 727 would be one
[Re: paddel]
#1918214
09/23/15 05:47 PM
09/23/15 05:47 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
The transmission gets a substantial amount of info from the ECU to perform it's own calculations and performance. Better look WAY deep into this before you shell out any money.
Physical fitment issues are basically dependent on how mechanical you are and what equipment/facility you have available.
Driving modern convenience in classic beauty
[Re: paddel]
#1918253
09/23/15 06:25 PM
09/23/15 06:25 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
ZF builds the tranmission for many car manufacturers (chrysler, BMW,..). The german site says that it has an integrated control system.
But that really isn't the problem.
My question is (and was) if it could fit to the engine.
Even if I would need an ECU, I can make that happen. You would need to make an adapter plate to go from small block to big block bolt pattern ... there is not one available that I have ever seen... Unless the bellhousing is removable then you could just adapt it to another bellhousing.
[Re: paddel]
#1918398
09/23/15 10:00 PM
09/23/15 10:00 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Assuming the trans you want to use has a small block bellhousing bolt pattern, this adapter would likely work for you. http://smrtrans.tripod.com/smrtransmissionsintro/id9.htmlYour biggest problem is going to be floor pan and torsion bar xmember clearance. You are almost certainly going to have to do some major fabrication there.
[Re: paddel]
#1918576
09/24/15 02:35 AM
09/24/15 02:35 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
If my memory serves me correctly, I believe that trans has a bolt on bell housing and the actual trans shares a lot of pieces with the AMG/Benz trans. If a unit like the Ultrabell was made for that, it would be a slam dunk. The Kiesler based 4L60E GM based trans uses a bolt on bell for other than GM/Chevy swaps. If you come up with a standalone controller, you may have something!
Carl Kessel
[Re: mgoblue9798]
#1918702
09/24/15 12:07 PM
09/24/15 12:07 PM
DaytonaTurbo
Manitoba, Canada
Assuming the trans you want to use has a small block bellhousing bolt pattern, this adapter would likely work for you. http://smrtrans.tripod.com/smrtransmissionsintro/id9.htmlYour biggest problem is going to be floor pan and torsion bar xmember clearance. You are almost certainly going to have to do some major fabrication there. What their website doesn't tell you clearly, is on your engine block you have to grind off your lower driver side transmission mounting ear. This ear gets in the way of the small block starter mounting location. If you don't do this, you won't be able to mount the starter unless you grind and reweld your SB bellhousing to accommodate the BB starter mounting location. If the ZF transmission has it's own starter system, you may be saved this headache. As for the trans controller, at a minimum I would expect the trans controller to want to see throttle position. Trans controller would also want to be tied into a speed sensor and engine RPM. If the ZF trans controller is expecting to receive this information through the OBD-2 CAN bus, I think you are screwed unless you can scrape together a controller to emulate this signal and provide the ZF ecu with a TPS, RPM and VSS signal at a minimum. The ZF controller could conceivably get it's own speed signal from it's speed sensor but I think for rpm and throttle position you would still be stuck. You would have to dive much deeper into this before you would even think about buying a transmission. You will have to plan to slice and dice your floor pan and torsion bar crossmember to make this fit. The old mopar transmissions were quite skinny compared to modern ones. I applaud your desire to put a modern transmission into your car, IMO it's the way to go to get the most out of your old car!
[Re: paddel]
#1918714
09/24/15 12:26 PM
09/24/15 12:26 PM
Darius
Sacramento, Ca
I have a 5 speed out of an 07 Charger in my GTX behind a 5.7 hemi. What a blast to drive and the mileage is great. MAJOR pain in the ass to get it to work without the stock speed sensors. Finally found a guy who wrote a program to manage this type of swap and that is what made it work. Nothing else we tried got us out of limp mode. You might want to talk to him. I don't know how much experience, if any, he has with the 8 speeds but it is worth asking. Russell Drake www.soundgermanautomotive.com
[Re: paddel]
#1918752
09/24/15 01:42 PM
09/24/15 01:42 PM
Posts: 107 germany
paddel
germany
thanks for all the help, links, contacts and explanations. That helped a lot. I also think I have to write a new program or use a dummy ECU. The real problem is the throttle position. Is there any carburetor with a sensor on it or do I have to switch to an EFI?
EDIT: I found a video where a guy modified an edelbrock to mount a throttle position sensor. Also the RPM shouldn't be a real problem. If the normal RPM signal from my distributor won't work I'll get another from msd. Sure it won't be just plug & play. But there is a basic transmission and you can add what you (more the car manufacturer) want.
[Re: paddel]
#1918764
09/24/15 01:57 PM
09/24/15 01:57 PM
DaytonaTurbo
Manitoba, Canada
Again, the ZF transmission controller is not going to be looking for a raw RPM input from a coil or MSD unit. It's most likely looking for this info through the CAN bus. Your friend at ZF is going to have to dig up a fair amount of technical info for you. Adapting a throttle position sensor to your carb is the easiest part of this whole swap. Something like this would work for you... http://www.hgmelectronics.com/products-t...tion-sensor-kit
[Re: paddel]
#1918771
09/24/15 02:07 PM
09/24/15 02:07 PM
Posts: 108 Ohio
ChallengerTA
Ohio
The trans talks to the rest of the control modules over CAN C. It gets vehicle speed from the ESC module. Throttle position, Engine RPM and others from the PCM. Your not going to be able to duplicate those signals. It would require a ton of software re-write to get it to work. Unless you get the hardware/software support of ZF it wont work.
Jason 1970 Challenger T/A
[Re: paddel]
#1919029
09/24/15 08:04 PM
09/24/15 08:04 PM
Posts: 107 germany
paddel
germany
the transmission can be shifted mechanical.
what about the edelbrock e-street EFI? It has a throttle position sensor, needs a RPM signal and much more for it's "ECU". Does it work with can bus? If so: it does not have any output. That would be an easy one then. But I don't think so.
EDIT: the holley terminator EFI has can bus. They have a digital dash to show RPM and such connected with can bus.
