Oval Porting B1's #1918043
09/23/15 01:32 PM
09/23/15 01:32 PM
Pennsylvania
shantyshakinstud Offline OP
Pennsylvania
I see some talk of "oval porting" B1 heads.
Looking to upgrade to either Indy 572-13 or B1 M/C Heads.
Any direction or input would be appreciated, such as who would you recommend for porting work on B1's, installing drain fittings, etc......
540", single four barrel carb with cast intake build per rules....
Re: Oval Porting B1's [Re: shantyshakinstud] #1918064
09/23/15 02:02 PM
09/23/15 02:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mike Duke....
Re: Oval Porting B1's [Re: shantyshakinstud] #1918070
09/23/15 02:13 PM
09/23/15 02:13 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What's the advantage of oval vs rectangular? Less dead space in the oval vs rectangular?
Re: Oval Porting B1's [Re: WO23Coronet] #1918112
09/23/15 03:22 PM
09/23/15 03:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
One of the ongoing debates in the World of head porting.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oval Porting B1's [Re: shantyshakinstud] #1918204
09/23/15 05:27 PM
09/23/15 05:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Velocity and if you look at most any high end cylinder head they are oval ports.
Re: Oval Porting B1's [Re: shantyshakinstud] #1918208
09/23/15 05:34 PM
09/23/15 05:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
A friend of mine has a 572-13 engine he has no use for if you are interested.
2011 Drag Pak Challenger
Re: Oval Porting B1's [Re: rickseeman] #1918222
09/23/15 05:59 PM
09/23/15 05:59 PM
Pennsylvania
Pennsylvania
I am open to all options at this point.
My email is mattpierce789@yahoo.com or PM his contact info.
Any estimates on cfm of the oval ported M/C stuff??
Re: Oval Porting B1's [Re: shantyshakinstud] #1918381
09/23/15 09:46 PM
09/23/15 09:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Benches vary and flow mean little with no velocity and too much cross section. You can have all the floor in the world but if the velocity is low then it wont matter a bit.
FWIW this is a 99/06 Hemi Pro stock head
Another
Re: Oval Porting B1's [Re: Al_Alguire] #1918460
09/23/15 11:13 PM
09/23/15 11:13 PM
Pennsylvania
Pennsylvania
Thanks. As a long time Indy 440-1 user, i am trying to learn as much as i can before jumping into the $ pool of a new top end.
Also, its difficult finding port volume ideas forthe b1mc stuffonline.
Re: Oval Porting B1's [Re: shantyshakinstud] #1918605
09/24/15 05:05 AM
09/24/15 05:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW in the right hands 460ish CFM is attainable
Re: Oval Porting B1's [Re: shantyshakinstud] #1918759
09/24/15 01:51 PM
09/24/15 01:51 PM
I've seen 450 CFM at or above .700 lift posted on here about regular style port B1MC heads, both of the ported B1 original I had flow sheets on said between 400 to 430 CFM at or above .700 lift getting a little better the more the valves opened work shruggy
Re: Oval Porting B1's [Re: shantyshakinstud] #1918780
09/24/15 02:15 PM
09/24/15 02:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW mine have been on 4 benches over the years and NEVER been under 465cfm
Re: Oval Porting B1's [Re: Al_Alguire] #1918914
09/24/15 05:17 PM
09/24/15 05:17 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
That's because Mike Duke is a port development genius!
But there is no way those flow numbers are real because he doesn't "specialize" in Mopars laugh2
Re: Oval Porting B1's [Re: shantyshakinstud] #1918987
09/24/15 06:53 PM
09/24/15 06:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
BINGO!!! smile
Re: Oval Porting B1's [Re: shantyshakinstud] #1919092
09/24/15 09:52 PM
09/24/15 09:52 PM
Pennsylvania
Pennsylvania
Anyone got contact info for Mike Duke?
Re: Oval Porting B1's [Re: shantyshakinstud] #1919132
09/24/15 10:33 PM
09/24/15 10:33 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I'll PM it to you
