Molasses as a rust remover question. #1917072
09/21/15 10:33 PM
09/21/15 10:33 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I have a block with the crank, rods, pistons, cam, lifters and distributor still in it that I am trying to get apart. I can't turn the camshaft or distributor. Will the molasses bath eat up anything in the distributor, or the aluminum housing. It is a point type GM unit. Also, can anyone advise on what ratio to mix powdered molasses to make the best rust remover.
Dan.
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917086
09/21/15 11:01 PM
09/21/15 11:01 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
The molasses didn't eat up anything I put in it but I will tell you this - it stinks to high heaven. Keep it covered TIGHTLY and use a fish tank heater to keep the stuff warm.
Sorry I can't help with the ratio as i used the liquid stuff.
Did I mention it stinks ?
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917339
09/22/15 12:52 PM
09/22/15 12:52 PM
Dan any possibility some solvent or WD40 would do the trick?
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917388
09/22/15 01:54 PM
09/22/15 01:54 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Buy a plastic or metal horse trough, also buy or fashion the tightest fitting lid you can because as mentioned, it reeks! Buy a 50lb sack of dry molasses powder (horse feed supply stores sell it, it's cheap) dump about half of it in the trough and fill the rest up with water (stop 8-10 inches from the top so adding parts doesn't over flow it). While at the feed store buy a water trough heater (keeps water from freezing so cattle can drink in winter) nothing fancy, most are cheap. hook up the heater, add the lid, and let it ferment for a couple weeks to a month (the warmer the faster). Once it's cooked up you can reuse it for a very long time. I've soaked 6 engine blocks in mine and the mixture has not degraded at all, a week or two and the nastiest rusty blocks are perfectly clean cast iron. I steam clean the grease off before soaking, not really required but grease can slow or stop the process where it's coating the metal.
FWIW Safest Rust Remover or Evaporust will do the same job but will cost a lot more.
.02
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917393
09/22/15 01:59 PM
09/22/15 01:59 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I use wood bleach to de rust stuff, few table spoons per gallon of warm water. A tub of it at ace is around $7
Re: Molasses as a rust remover question. [Re: ScottSmith_Harms] #1917545
09/22/15 06:19 PM
09/22/15 06:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
.02
Good advice, I going to use a 55 gallon drum for my block(hope it fits)
Re: Molasses as a rust remover question. [Re: cudaman1969] #1917754
09/22/15 11:11 PM
09/22/15 11:11 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Robert, I think I am way past the WD40 or solvent. To bad this engine was left sitting the way it was.
Dan.
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917757
09/22/15 11:14 PM
09/22/15 11:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Dan.
Wasn't that the engine found in that civil war sub?
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917760
09/22/15 11:16 PM
09/22/15 11:16 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Scott, I'm going to use a 55 gallon drum. If I add 25 pound of molasses, would about 30 gallon of water be about right? I'm not sure how big a trough is, not much of a farmer, lol. Can a complete carb be dipped in this, as all the linkage and other metal parts are rusty.
Dan.
Re: Molasses as a rust remover question. [Re: mopar4ya] #1917865
09/23/15 02:01 AM
09/23/15 02:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes Dan, not an exact science, you want a lot of molasses but you want to end up with a watery solution (not thick and gooey). The carb and all that will work fine. This mixture will de-rust a block as bad as Cudaman1969 posted
Re: Molasses as a rust remover question. [Re: cudaman1969] #1918116
09/23/15 03:26 PM
09/23/15 03:26 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Dan.
No, it was the Mayflower.
Dan.
Re: Molasses as a rust remover question. [Re: mopar4ya] #1918123
09/23/15 03:33 PM
09/23/15 03:33 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Was it used as an anchor on the Mayflower?
Re: Molasses as a rust remover question. [Re: mopar4ya] #1918251
09/23/15 06:19 PM
09/23/15 06:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Electrolytic rust removal! I built one and it works great. Cheaper than 25 gallons of molasses
http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
Re: Molasses as a rust remover question. [Re: R/T1968R/T] #1918439
09/23/15 10:44 PM
09/23/15 10:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Been looking at this myself, got any pics?
Re: Molasses as a rust remover question. [Re: mopar4ya] #1918627
09/24/15 09:12 AM
09/24/15 09:12 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
I use a 10:1 water to (liquid) molasses mix, no heater - generally hot where i live, takes a while, helps if you give it a scrub and agitate it every few days
+1 on the steam clean first
Lol at the smell - my vat has been banished to the far end of our yard
I am in no way an engineer of any sort, but as far as i know electrolysis will eat the weakest metals first, so if its an ally dizzy, go the molasses
Re: Molasses as a rust remover question. [Re: cudaman1969] #1919014
09/24/15 07:34 PM
09/24/15 07:34 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The one I built looks just like the picture. a 5 gallon bucket and some rebar. I welded bolts to the rebar then put them through the bucket and used wire nuts instead. I did a rusty cylinder head just like the block. It comes out with a black dust on it. Power washed it and it looked like new!
