Re: Molasses as a rust remover question.
[Re: mopar4ya]
#1917086
09/21/15 11:01 PM
09/21/15 11:01 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
The molasses didn't eat up anything I put in it but I will tell you this - it stinks to high heaven. Keep it covered TIGHTLY and use a fish tank heater to keep the stuff warm.
Sorry I can't help with the ratio as i used the liquid stuff.
Did I mention it stinks ?
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: mopar4ya]
#1917339
09/22/15 12:52 PM
09/22/15 12:52 PM
RapidRobert
Dan any possibility some solvent or WD40 would do the trick?
[Re: mopar4ya]
#1917388
09/22/15 01:54 PM
09/22/15 01:54 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Buy a plastic or metal horse trough, also buy or fashion the tightest fitting lid you can because as mentioned, it reeks! Buy a 50lb sack of dry molasses powder (horse feed supply stores sell it, it's cheap) dump about half of it in the trough and fill the rest up with water (stop 8-10 inches from the top so adding parts doesn't over flow it). While at the feed store buy a water trough heater (keeps water from freezing so cattle can drink in winter) nothing fancy, most are cheap. hook up the heater, add the lid, and let it ferment for a couple weeks to a month (the warmer the faster). Once it's cooked up you can reuse it for a very long time. I've soaked 6 engine blocks in mine and the mixture has not degraded at all, a week or two and the nastiest rusty blocks are perfectly clean cast iron. I steam clean the grease off before soaking, not really required but grease can slow or stop the process where it's coating the metal.
FWIW Safest Rust Remover or Evaporust will do the same job but will cost a lot more.
.02
[Re: ScottSmith_Harms]
#1917545
09/22/15 06:19 PM
09/22/15 06:19 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
.02 Good advice, I going to use a 55 gallon drum for my block(hope it fits)
[Re: mopar4ya]
#1917757
09/22/15 11:14 PM
09/22/15 11:14 PM
cudaman1969
fredericksburg,va
Robert, I think I am way past the WD40 or solvent. To bad this engine was left sitting the way it was. ![](http://i105.photobucket.com/albums/m222/mopar4ya/DSC06037_zpshkhct3jv.jpg) ![](http://i105.photobucket.com/albums/m222/mopar4ya/DSC06072_zpsocq7n3hu.jpg) Thanks Dan. Wasn't that the engine found in that civil war sub?
[Re: cudaman1969]
#1918116
09/23/15 03:26 PM
09/23/15 03:26 PM
Posts: 2,655 western PA
mopar4ya
western PA
Robert, I think I am way past the WD40 or solvent. To bad this engine was left sitting the way it was. ![](http://i105.photobucket.com/albums/m222/mopar4ya/DSC06037_zpshkhct3jv.jpg) ![](http://i105.photobucket.com/albums/m222/mopar4ya/DSC06072_zpsocq7n3hu.jpg) Thanks Dan. Wasn't that the engine found in that civil war sub? No, it was the Mayflower. Dan.
