More slow-mo shock videos #1917111
09/21/15 11:41 PM
09/21/15 11:41 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
https://youtu.be/hexnHjhuotE
Bear with me on the video of a video. It's crazy how hard it hits the tire. And that's a radial tire too.
Re: More slow-mo shock videos [Re: 1980volare] #1917138
09/22/15 12:03 AM
09/22/15 12:03 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Says video is private.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: More slow-mo shock videos [Re: 1980volare] #1917148
09/22/15 12:14 AM
09/22/15 12:14 AM
Dayton, OH
Dayton, OH
Fixed
Re: More slow-mo shock videos [Re: 1980volare] #1917159
09/22/15 12:33 AM
09/22/15 12:33 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Is your rear back braced, and what rear are you running?
Re: More slow-mo shock videos [Re: 1967dartgt] #1917167
09/22/15 12:43 AM
09/22/15 12:43 AM
Dayton, OH
Dayton, OH
Nope. 8.75
Re: More slow-mo shock videos [Re: 1980volare] #1917171
09/22/15 12:59 AM
09/22/15 12:59 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My radial leaving.
Re: More slow-mo shock videos [Re: 1980volare] #1917173
09/22/15 01:00 AM
09/22/15 01:00 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Almost looks like the axle is deflecting quite a bit.
Re: More slow-mo shock videos [Re: 1980volare] #1917235
09/22/15 07:35 AM
09/22/15 07:35 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I does look like something is flexing under there. It would be a good idea to get a camera under the car to see what it is.....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: More slow-mo shock videos [Re: 1980volare] #1917246
09/22/15 09:18 AM
09/22/15 09:18 AM
Dayton, OH
Dayton, OH
I've watched it and don't see what you're seeing. I wonder of some of it is my unsteady hands taking a video of my phone with my tablet.
But it's definitely possible.
Re: More slow-mo shock videos [Re: 1980volare] #1917250
09/22/15 09:23 AM
09/22/15 09:23 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Do you have video from other side of car?
Re: More slow-mo shock videos [Re: 1980volare] #1917256
09/22/15 09:32 AM
09/22/15 09:32 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The rear end deflects forward before the car moves. If you have rubber spring eye bushings or rubber mounts anywhere else there prolly wore out. Need to fix that soon.
Love the car
Re: More slow-mo shock videos [Re: 1967dartgt] #1917276
09/22/15 10:15 AM
09/22/15 10:15 AM
Dayton, OH
Dayton, OH
I do not. It does have factory oval eye bushings up front, so that's probably it. Going to switch to monos over winter
Re: More slow-mo shock videos [Re: 1980volare] #1917278
09/22/15 10:26 AM
09/22/15 10:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
After watching the video several times it looks like it's wadding the tire up and collapsing the front sidewall. Like the tire is stuck to the track and the wheel is trying to move forward in the tire.
How much air pressure?
Re: More slow-mo shock videos [Re: 1980volare] #1917288
09/22/15 10:56 AM
09/22/15 10:56 AM
an8sec70cuda Offline
I agree, looks like something is flexing or moving that shouldn't be. Looks like the shocks need to be stiffer on extension...hard hit.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: More slow-mo shock videos [Re: justinp61] #1917293
09/22/15 11:04 AM
09/22/15 11:04 AM
Dayton, OH
Dayton, OH
17lbs here. It wads up pretty hard. I'm going to try to add a couple psi next time out.
Re: More slow-mo shock videos [Re: 1980volare] #1917365
09/22/15 01:22 PM
09/22/15 01:22 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I would bet that the oval bushings are the problem then. They were meant for a comfy ride. The monos will definitely make the car more consistent just because the elimination of the bushings.
Scott
