No Brake Lights #1916251
09/20/15 07:25 PM
09/20/15 07:25 PM
Indiana
Cuda_Mike Offline OP
Indiana
After some evasive maneuvering to avoid being broadsided, my brake lights quit working. May not be related but that's when I noticed this. Have power through the brake light switch, checked several things, suspect the turn signal switch. Any ideas would be appreciated, I hate working under the dash! '69 GTX 4 spd.
Re: No Brake Lights [Re: Cuda_Mike] #1916266
09/20/15 07:45 PM
09/20/15 07:45 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you of course checked the ground but if you were braking hard/pumping the pedal, you might want to make sure the switch is being engaged/dis-engaged.
Re: No Brake Lights [Re: mikemee1331] #1916334
09/20/15 09:45 PM
09/20/15 09:45 PM
Indiana
Indiana
I've checked about everything, turn signals work, tailights work, 12 volts through brake light switch. Connector between brake light switch and turn signal switch appears good, leaning toward turn signal switch. Where are quality turn signal switches available?
Re: No Brake Lights [Re: Cuda_Mike] #1916347
09/20/15 10:06 PM
09/20/15 10:06 PM
If your TS work then from the dangling under the column pull apart connector rearward you are good (as far as brake lights). Seperate that connector and (1) you should have fire in the white wire in the body half of the connector when the brake pedal is depressed and (2) in the column half of the connector there should be continuity between the white wire terminal and the (2) "out" wire terminals to the dr/pass rear brake light large filaments WITH the stalk in neutral. www.mymopar.com will have the colors
Re: No Brake Lights [Re: Cuda_Mike] #1916402
09/20/15 11:11 PM
09/20/15 11:11 PM
BDW Offline
BDW  Offline
Try this
Re: No Brake Lights [Re: BDW] #1916510
09/21/15 02:57 AM
09/21/15 02:57 AM
Try this
good info
Re: No Brake Lights [Re: Cuda_Mike] #1916821
09/21/15 04:43 PM
09/21/15 04:43 PM
usa
smos001 Offline
smos001  Offline
usa
I had same problem,
Here is my discussion and fix.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1900782
