8 3/4 disc brake conversion inquiry #1915632
09/19/15 01:45 PM
09/19/15 01:45 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
"For the love of god! Not another 8 3/4 disc brake conversion thread!!"
Has anyone done this economically by using junkyard parts and it ACTUALLY worked?
Please no links with pages of tech info where it says you have to clap your hands, take 7 steps forward, read Mopar witchcraft, etc. And also don't post links that have a new disc brake billet kit for $900+.
Just trying to economically put disc's on the rear of my big block Dart.
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915667
09/19/15 02:24 PM
09/19/15 02:24 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I use ford rotors off of an explorer front, gm small metric calipers (monte carlo, 83) and weld on gm caliper mounts, im happy with it, done it to a few of my vehicles, along with customers, they get new stuff, ill use junkyard parts, lol.
Gotta shave a bit off the weld on mounts. The axle is bigger diameter than what a ford nine inch is. I clamp the bracket to the rotor with a one inch square tube to space it away. Just have to have the caliper bolts screwed in and just the width of a washer away from the rotors edge. You get it to close, the rotor will rub.
I hate drums, so i do this swap all the time, basically the same thing every circle track car has.
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915669
09/19/15 02:24 PM
09/19/15 02:24 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Dr. Diff
Mopar to the bone!!!
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915674
09/19/15 02:31 PM
09/19/15 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Scarebird (no I won't paste a link) offers $135 brackets that use junkyard parts ('82-'87 Lincoln rotors and 1979-85 Cadillac Eldorado calipers).
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915676
09/19/15 02:40 PM
09/19/15 02:40 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
There are no "junkyard" Mopar rear disc brake conversions that will simply bolt to an 8.75" rear.
The closest thing is a Jeep set up, but this requires machine work.
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915940
09/20/15 12:30 AM
09/20/15 12:30 AM
AndyF Offline
AndyF  Offline
There isn't a cheap easy junkyard kit that works. That is why people worked on developing kits. The DoctorDiff kit is the best one available. A lot of the other kits don't work much better than the home built junkyard setups.
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915941
09/20/15 12:32 AM
09/20/15 12:32 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Doctor Diff's kit, as far as I know, is also the only one that allows you to use factory-style tapered axle bearings. All of the other ones require Green Bearings.
Re: 8 3/4 disc brake conversion inquiry [Re: WS68SSC] #1915967
09/20/15 02:26 AM
09/20/15 02:26 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Used Ford 8.8 (disc brakes, LSD, good factory gear ratios) from a Ford Explorer can be had from 250-400 buck s at a junkyard. A set of perches and a quick stop at the driveshaft shop and you are in!
