69 Super Bee pinion and brake offset #1915355
09/18/15 11:15 PM
09/18/15 11:15 PM
Hamilton, Ontario Canada
Magnum Offline OP
Magnum  Offline OP
I'm having a custom length S60 made from my car.
It's a 69 Super Bee with the leaf springs relocated 3" inboard.
I mocked up the wheels under the car and measured wheel flange to wheel flange.
The spec sheet is asking for pinion offset and brake offset.
Re: 69 Super Bee pinion and brake offset [Re: Magnum] #1915494
09/19/15 04:22 AM
09/19/15 04:22 AM
what is an S60?. here's a BTT for ya
Re: 69 Super Bee pinion and brake offset [Re: Magnum] #1915499
09/19/15 05:43 AM
09/19/15 05:43 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Strange Dana 60 I am guessing. Pinion offset would be if you want it in the middle or offset to one side or the other. Brake I am not 100% sure of.
Re: 69 Super Bee pinion and brake offset [Re: slantzilla] #1915576
09/19/15 12:04 PM
09/19/15 12:04 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
S60 is the Strange housing with threaded carrier bearing adjusters, no shims or case spreader needed to achieve preload.
Pinion offset on a Dana 60 is not be the same as a 8.75. Dana 60 uses different axle lengths, 8.75 are equal length. I would spec the pinion offset the same as an OEM D60.
I'm guessing brake offset will be the distance from the housing flange to the axle flange.
Re: 69 Super Bee pinion and brake offset [Re: RapidRobert] #1920903
09/27/15 11:22 PM
09/27/15 11:22 PM
Magnum Offline OP
Magnum  Offline OP
An S60 is essentially a new and improved Dana60.
For the sake of my question. What rear end doesn't actually matter. I need the pinion offset for a 68-70 B body.
Re: 69 Super Bee pinion and brake offset [Re: Magnum] #1921127
09/28/15 12:10 PM
09/28/15 12:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Call DR Diff on the board.He can set you up with everything.There are measurements in the tech archives.Dana factory is offset about 1 3/8 inch longer on DS.IIRC.Rocky
Chrysler Firepower
Re: 69 Super Bee pinion and brake offset [Re: Magnum] #1927406
10/06/15 11:47 PM
10/06/15 11:47 PM
Magnum Offline OP
Magnum  Offline OP
My builder is Bear's and they said 1 3/16" to the passenger side.
Dr Diff said stock 4.5 on 5 Mopar is 2.525"
