Re: paint sputters problem
[Re: Alexdodge]
#1914213
09/17/15 01:52 AM
09/17/15 01:52 AM
moparpollack
Lil Herman
Lil Herman
85086
It sucks but a $20 HVLP gun from Harbor Freight is better than most siphon guns. If you continue to use a siphon gun make sure the vent hold is open or else the gun will spray like crap.
Be sure the tip matches the p sheet for the product.
[Re: Alexdodge]
#1914320
09/17/15 10:46 AM
09/17/15 10:46 AM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
Air vent in the cup is probably clogged.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
[Re: Alexdodge]
#1914324
09/17/15 10:51 AM
09/17/15 10:51 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
there is a air leak behind the fluid tip or the packing's for the fluid needle. it's probably the fluid tip. if the cup vent were plugged the paint won't spray out of the gun.
it doesn't matter if it's a high or low $$$ gun they all can have this problem.
perception is 90% of reality
[Re: chrisf]
#1915025
09/18/15 01:19 PM
09/18/15 01:19 PM
Challenger 1
Cincinnati, Ohio
make sure the nozzle is tight and not leaking air (nozzle is under the air cap)
and yes. most syphon guns are junk. I don't use a siphon gun anymore, but executed many fine paint jobs with one years ago. Take that back, I still use one on my paint pot.
