a body 727 linkage needed #1911941
09/13/15 11:17 PM
09/13/15 11:17 PM
ohio
drce2 Offline OP
drce2  Offline OP
ohio
I need trans linkage for a 67 dart with 440/727 with factory console.used or does anyone reproduce?not kickdown but the shifter linkage.thanks
Re: a body 727 linkage needed [Re: drce2] #1912024
09/14/15 01:10 AM
09/14/15 01:10 AM
ohio
drce2 Offline OP
drce2  Offline OP
ohio
basicly I need shifter linkage from 383 67-69 a body I think,i cant find where to buy it new or repro,used?help
Re: a body 727 linkage needed [Re: drce2] #1912055
09/14/15 03:38 AM
09/14/15 03:38 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I would think that the shifter linkage would be the same for any floor shift A-Body.
It shouldn't matter if it was from a small block or a big block.
I reused the shifter linkage from my 273/904 combo and installed it on the 572 Hemi and 727 that went in my car.
I didn't even have to adjust it, lined right up.
Kick down linkage would be different between small block and big block but shifter linkage should be the same.
The big block A-Body kick down linkage is specific to just A-Bodies.
I know it's reproduced, but not cheap.
Re: a body 727 linkage needed [Re: SNK-EYZ] #1912092
09/14/15 10:25 AM
09/14/15 10:25 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
iagree with what is said above... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: a body 727 linkage needed [Re: drce2] #1912109
09/14/15 11:14 AM
09/14/15 11:14 AM
ohio
drce2 Offline OP
drce2  Offline OP
ohio
thanks guys,now to find it somewhere!i wasn't going to use the kickdown,i don't have to have it,right?
Re: a body 727 linkage needed [Re: drce2] #1912121
09/14/15 11:38 AM
09/14/15 11:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A 727 is a 727 , the engine doesn't matter . A want ad in the right place should get you what you seek.
Re: a body 727 linkage needed [Re: drce2] #1912122
09/14/15 11:39 AM
09/14/15 11:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Only if you are running a manual valve body that doesn't require it.
Re: a body 727 linkage needed [Re: drce2] #1912194
09/14/15 01:15 PM
09/14/15 01:15 PM
ohio
drce2 Offline OP
drce2  Offline OP
ohio
its a manual or auto valve body. what kick down would work?its also a cross ram.
Re: a body 727 linkage needed [Re: drce2] #1912209
09/14/15 01:36 PM
09/14/15 01:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A Bouchillon kick down cable kit may be your best bet. http://www.bouchillonperformance.com/trans_kickdown_cables
Re: a body 727 linkage needed [Re: drce2] #1912215
09/14/15 01:48 PM
09/14/15 01:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What do you mean it's a manual or auto valvebody , it's one or the other, which is it?
and yes I know an automatic valvebody can be shifted manually.
Re: a body 727 linkage needed [Re: JohnRR] #1912229
09/14/15 02:06 PM
09/14/15 02:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A little educational info for you.
TCI's StreetFighter valve bodies give you better control over your transmission, while improving your car's overall performance. They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire. Great for street and racing use, they come ready for installation and are the same valve bodies installed by TCI in their famous StreetFighter series transmissions.
http://www.tciauto.com/tc/727-904-streetfighterr-valve-bodyhtml/
Re: a body 727 linkage needed [Re: drce2] #1912243
09/14/15 02:36 PM
09/14/15 02:36 PM
ohio
drce2 Offline OP
drce2  Offline OP
ohio
thanks so much for all the help
Re: a body 727 linkage needed [Re: stumpy] #1912413
09/14/15 08:01 PM
09/14/15 08:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Oh you mean like your run of the mill VB that Chrysler installed in their transmissions ???
Thanks for the education ...
Re: a body 727 linkage needed [Re: drce2] #1912416
09/14/15 08:11 PM
09/14/15 08:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No not the run of the mill VB. You might actually try doing some research before making stupid statements.
Re: a body 727 linkage needed [Re: JohnRR] #1913498
09/16/15 02:57 AM
09/16/15 02:57 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Try Classic Industries. They have everything you need.
Abe Lincoln
Re: a body 727 linkage needed [Re: stumpy] #1913764
09/16/15 03:41 PM
09/16/15 03:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Their selling point is "They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire." Just like an untouched factory VB.
And their claim isn't exactly true because you don't have "full manual" control and factors other than the VB control automatic shifting.
Re: a body 727 linkage needed [Re: John_Kunkel] #1913837
09/16/15 04:49 PM
09/16/15 04:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
work
Re: a body 727 linkage needed [Re: drce2] #1913858
09/16/15 05:19 PM
09/16/15 05:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
In my experience with that valve body I got more precise up and down shifts and a more solid shift. So it is a better VB than the RUN OF THE MILL factory equipment.
Re: a body 727 linkage needed [Re: drce2] #1913865
09/16/15 05:32 PM
09/16/15 05:32 PM
IMGTX Offline
IMGTX  Offline
As a general rule if it can shift itself (Auto Mode) it will need a kickdown.
A FULL manual valve body will require you to shift it all the time.
Re: a body 727 linkage needed [Re: drce2] #1913938
09/16/15 07:02 PM
09/16/15 07:02 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
If you don't have a full manual valve body (one you have to manually shift all the time), you need to use a kickdown (linkage or cable) to avoid damaging the transmission.
When you work on Spaceships for a living, how bad can a workday be?
