Holley Street Dominator Help #1912547
09/14/15 10:28 PM
09/14/15 10:28 PM
NY
Beep Beep Offline OP
NY
Hi everyone,
I am going to be installing my big block Holley street dominator intake on my low deck stroker motor. I am running the Holley double pumper carb. Do I need to run a spread bore to square bore adapter?
Re: Holley Street Dominator Help [Re: Beep Beep] #1912678
09/15/15 12:01 AM
09/15/15 12:01 AM
AndyF Offline
AndyF  Offline
Depends how much room you have. I'd use at least a 1/2 inch open spacer just to eliminate the chances of having a vacuum leak around the sides of the carb.
Re: Holley Street Dominator Help [Re: Beep Beep] #1912686
09/15/15 12:08 AM
09/15/15 12:08 AM
NY
NY
Thanks Andy. I am kind of limited for space. I am running this with a fresh air package on a 69 RR. I could mill the top of the intake 1/8 and install the open spacer. Not sure if I can get away with the 1/2.
Re: Holley Street Dominator Help [Re: Beep Beep] #1912758
09/15/15 01:41 AM
09/15/15 01:41 AM
get the thin square plate (an eddy # iirc). it'll cover the offending secondary scalloped flange areas. Gasket then the plate then another gasket then the carb. EDIT eddy #2732 adapter, .100" thick
Re: Holley Street Dominator Help [Re: RapidRobert] #1912896
09/15/15 11:33 AM
09/15/15 11:33 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Just bolt it on with a good gasket and don't worry about it. Mine worked fine with no leaks for many years. Thin plates are a recipe for a broken carb base.
Re: Holley Street Dominator Help [Re: Beep Beep] #1912911
09/15/15 11:50 AM
09/15/15 11:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree just bolt on.My kid ran mine after I did and we bothe ran DPs with no problems.You might need a throttle bracket but thats it.Rocky
Chrysler Firepower
Re: Holley Street Dominator Help [Re: Beep Beep] #1913384
09/15/15 11:29 PM
09/15/15 11:29 PM
NY
NY
Thanks everyone for the feedback. Greatly appreciated!
Re: Holley Street Dominator Help [Re: Beep Beep] #1913546
09/16/15 10:17 AM
09/16/15 10:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Seems to me I used a 1/2" spacer because my DP linkage hit the manifold so I needed to raise my 850 DP a little and I used a phenolic spacer. Ron
Re: Holley Street Dominator Help [Re: Beep Beep] #1913587
09/16/15 12:01 PM
09/16/15 12:01 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Mill the spacer as needed. I remember a article that stated what 383man said about the need for a spacer & a Holley. I run a TQ on mine, but it is a lowly stock 400.
Re: Holley Street Dominator Help [Re: Beep Beep] #1914729
09/17/15 10:54 PM
09/17/15 10:54 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
I run a 750 DP and my linkage also hit the intake. Had to use a spacer for it to clear.
68 dart, 383, 727
2013 Jeep JKU Sahara
