Re: a body 727 linkage needed
[Re: drce2]
#1912055
09/14/15 03:38 AM
09/14/15 03:38 AM
Posts: 10,161 A Red State
SNK-EYZ
A Red State
I would think that the shifter linkage would be the same for any floor shift A-Body.
It shouldn't matter if it was from a small block or a big block.
I reused the shifter linkage from my 273/904 combo and installed it on the 572 Hemi and 727 that went in my car. I didn't even have to adjust it, lined right up.
Kick down linkage would be different between small block and big block but shifter linkage should be the same.
The big block A-Body kick down linkage is specific to just A-Bodies. I know it's reproduced, but not cheap.
[Re: drce2]
#1912121
09/14/15 11:38 AM
09/14/15 11:38 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I need trans linkage for a 67 dart with 440/727 with factory console.used or does anyone reproduce?not kickdown but the shifter linkage.thanks A 727 is a 727 , the engine doesn't matter . A want ad in the right place should get you what you seek.
[Re: drce2]
#1912122
09/14/15 11:39 AM
09/14/15 11:39 AM
JohnRR
thanks guys,now to find it somewhere!i wasn't going to use the kickdown,i don't have to have it,right? Only if you are running a manual valve body that doesn't require it.
[Re: drce2]
#1912215
09/14/15 01:48 PM
09/14/15 01:48 PM
JohnRR
its a manual or auto valve body. what kick down would work?its also a cross ram. What do you mean it's a manual or auto valvebody , it's one or the other, which is it? and yes I know an automatic valvebody can be shifted manually.
[Re: JohnRR]
#1912229
09/14/15 02:06 PM
09/14/15 02:06 PM
Posts: 32,977 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
its a manual or auto valve body. what kick down would work?its also a cross ram. What do you mean it's a manual or auto valvebody , it's one or the other, which is it? and yes I know an automatic valvebody can be shifted manually. A little educational info for you. TCI's StreetFighter valve bodies give you better control over your transmission, while improving your car's overall performance. They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire. Great for street and racing use, they come ready for installation and are the same valve bodies installed by TCI in their famous StreetFighter series transmissions. http://www.tciauto.com/tc/727-904-streetfighterr-valve-bodyhtml/
[Re: stumpy]
#1912413
09/14/15 08:01 PM
09/14/15 08:01 PM
JohnRR
its a manual or auto valve body. what kick down would work?its also a cross ram. What do you mean it's a manual or auto valvebody , it's one or the other, which is it? and yes I know an automatic valvebody can be shifted manually. A little educational info for you. TCI's StreetFighter valve bodies give you better control over your transmission, while improving your car's overall performance. They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire. Great for street and racing use, they come ready for installation and are the same valve bodies installed by TCI in their famous StreetFighter series transmissions. http://www.tciauto.com/tc/727-904-streetfighterr-valve-bodyhtml/ Oh you mean like your run of the mill VB that Chrysler installed in their transmissions ??? Thanks for the education ...
[Re: JohnRR]
#1913498
09/16/15 02:57 AM
09/16/15 02:57 AM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Try Classic Industries. They have everything you need.
Abe Lincoln
[Re: stumpy]
#1913764
09/16/15 03:41 PM
09/16/15 03:41 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No not the run of the mill VB. You might actually try doing some research before making stupid statements. Their selling point is "They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire." Just like an untouched factory VB. And their claim isn't exactly true because you don't have "full manual" control and factors other than the VB control automatic shifting.
[Re: John_Kunkel]
#1913837
09/16/15 04:49 PM
09/16/15 04:49 PM
JohnRR
[Re: drce2]
#1913865
09/16/15 05:32 PM
09/16/15 05:32 PM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
its a manual or auto valve body. what kick down would work?its also a cross ram. As a general rule if it can shift itself (Auto Mode) it will need a kickdown. A FULL manual valve body will require you to shift it all the time.
[Re: drce2]
#1913938
09/16/15 07:02 PM
09/16/15 07:02 PM
Posts: 406 California City, CA
dart440
California City, CA
If you don't have a full manual valve body (one you have to manually shift all the time), you need to use a kickdown (linkage or cable) to avoid damaging the transmission.
When you work on Spaceships for a living, how bad can a workday be?
