Help with throttle cable bracket #1911909
09/13/15 10:34 PM
09/13/15 10:34 PM
NY
Beep Beep Offline OP
NY
I would like some help with the throttle bracket on my low deck 499 stroker motor. I am running the Holley street dominator intake, but the factory throttle bracket will not sit properly on the intake. Has anyone figured out which bracket will work with this intake? I am running the factory cable.
Re: Help with throttle cable bracket [Re: Beep Beep] #1911922
09/13/15 10:51 PM
09/13/15 10:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would go with the AR Engineering throttle bracket.
I will work with just about any manifold and you can put the cable bracket in the place where it fits best.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Help with throttle cable bracket [Re: Beep Beep] #1911943
09/13/15 11:20 PM
09/13/15 11:20 PM
NY
NY
Gus,
Is that the extra tall or standard tall bracket from AR Engineering?
Re: Help with throttle cable bracket [Re: Beep Beep] #1911958
09/13/15 11:30 PM
09/13/15 11:30 PM
AndyF Offline
AndyF  Offline
The one in the picture is the extra tall version. Generally with a Dominator you need the extra tall. A Holley SD is a fairly short intake so the standard bracket should work unless you're going to run a really tall carb spacer.
Re: Help with throttle cable bracket [Re: Beep Beep] #1911979
09/13/15 11:59 PM
09/13/15 11:59 PM
NY
NY
Thanks Andy! I will order the standard bracket tomorrow. Will this also work with the performer rpm with the holley dp?
Re: Help with throttle cable bracket [Re: Beep Beep] #1912149
09/14/15 12:15 PM
09/14/15 12:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with Gus.I run the tall one on my 65 B body 440 M1 with Dominator.My kid ran the Holleys on his 62 413 with stock linkage but it was linkage not cable.Rocky
Chrysler Firepower
Re: Help with throttle cable bracket [Re: Beep Beep] #1912649
09/14/15 11:43 PM
09/14/15 11:43 PM
NY
NY
Thanks guys for the feedback.
