Stuck 383?
#190962
01/11/09 10:03 PM
01/11/09 10:03 PM
Posts: 196 West Central Indiana
Mr.Runum
What is the best way to disassemble a motor that is stuck. 383 been sitting many yrs in a shed on the back of the block upright, cyls were filled with oil, but too late. I have it down to the crank, rods and pistons. I don't care about the rods or pistons, but the crank journals look good and the block should be. How do you get a stuck motor apart? Would like to not be as "crude" as possible, but the motor is going to be taken apart.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Stuck 383?
[Re: DaytonaTurbo]
#190964
01/12/09 12:26 AM
01/12/09 12:26 AM
RapidRobert
since aluminum is pretty soft you might drill the heck out of each piston top until all rods are free from the pistons then lift the crank/rod assy's out then see about tapping what's left of the piston tops down into & out of the bores.
Re: Stuck 383?
[Re: Mr.Runum]
#190965
01/12/09 09:56 AM
01/12/09 09:56 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Aero Kroil.... http://www.kanolabs.com/Not cheap...but I have seen it take many many things apart...like completely rusted shut AFB carbs....
Re: Stuck 383?
[Re: BSB67]
#190969
01/12/09 09:27 PM
01/12/09 09:27 PM
Mr.Runum
The winner is AERO KROIL . That is what I started with yesterday after getting down to just the short block. Things were tight. Let set over night, came home from work and sprayed down again, then after dinner away I went. Some of the pistons came out like they were in butter . Got all eight out with out any damage to the block or crank. Journals all looked good as did the cylinders. It looked like they had taken the intake and exhaust manifolds off and turned up on end and the oil had moisture and turned to sludge. Now I have a good 68 383 and steel crank for sale. Thanks for all replys.
Re: Stuck 383?
[Re: Mr.Runum]
#190970
01/12/09 09:31 PM
01/12/09 09:31 PM
RapidRobert
that stuff must be something else, I'm gonna have to try it.
Re: Stuck 383?
[Re: NTOLERANCE]
#190972
01/12/09 10:16 PM
01/12/09 10:16 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
You know I haven't even heard of that before until I went to work for Modine. They use it like it's going out of style. I've got a 440 stuck at the moment. I'm needing to get it apart. I'll probably try it, I never even thought about it before.
Moparlee
Re: Stuck 383?
[Re: NTOLERANCE]
#190973
01/14/09 12:40 AM
01/14/09 12:40 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Its like $14.00 a can...
It works because it is molecularly (is that a word?) smaller than most other penetrants. This allows it to creep into the smallest places most other penetrants cant.
My mother in law worked for them at one time.
Friend of mine had a pair of matching AFB carbs that had been stuck for a decade or more. He had tried soaking them in a tub of WD 40, and a host of other oils and penetrants. Finally he gave up. Few years later I gave him a can of kroil....one can. Sat over nite, and they freed right up.
I'm still find this hard to believe , we had it at work and it SUCKED , WD 40 worked as good if not better .
Re: Stuck 383?
[Re: NTOLERANCE]
#190977
01/15/09 10:24 AM
01/15/09 10:24 AM
JohnRR
U.S.S.A.
Aero Kroil....
I tried it on a stuck AVS , how many years do you have to leave the carb in there ? I left one in for a MONTH , it's STILL stuck SOLID
Re: Stuck 383?
[Re: JohnRR]
#190978
01/15/09 11:08 AM
01/15/09 11:08 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Put me on the Kroil bandwagon.
I used to buy my own and keep it in my toolbox, even though the shops I worked at stocked WD-40, CRC, Seafoam, or some other stuff.
-bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
