Stuck 383? #190962
01/11/09 10:03 PM
01/11/09 10:03 PM
West Central Indiana
Mr.Runum Offline OP
Mr.Runum  Offline OP
What is the best way to disassemble a motor that is stuck. 383 been sitting many yrs in a shed on the back of the block upright, cyls were filled with oil, but too late. I have it down to the crank, rods and pistons. I don't care about the rods or pistons, but the crank journals look good and the block should be.
How do you get a stuck motor apart? Would like to not be as "crude" as possible, but the motor is going to be taken apart.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Stuck 383? [Re: Mr.Runum] #190963
01/11/09 11:03 PM
01/11/09 11:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard filling the cylinders with diesel or ATF works. Fill it, let it sit for a few days while topping it up, then put on your breaker bar.
Re: Stuck 383? [Re: DaytonaTurbo] #190964
01/12/09 12:26 AM
01/12/09 12:26 AM
since aluminum is pretty soft you might drill the heck out of each piston top until all rods are free from the pistons then lift the crank/rod assy's out then see about tapping what's left of the piston tops down into & out of the bores.
Re: Stuck 383? [Re: Mr.Runum] #190965
01/12/09 09:56 AM
01/12/09 09:56 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Aero Kroil....
http://www.kanolabs.com/
Not cheap...but I have seen it take many many things apart...like completely rusted shut AFB carbs....
Re: Stuck 383? [Re: RapidRobert] #190966
01/12/09 11:19 AM
01/12/09 11:19 AM
Manitoba, Canada
Manitoba, Canada
That's not a bad idea robert. If you have a carbide bit for your dremel, you could probably dremel out that area of the piston until the rod comes free, but I'm sure you'd end up nicking the bore, and the last thing you want to do is mess it up so bad you have to sleeve it.
Re: Stuck 383? [Re: NTOLERANCE] #190967
01/12/09 02:45 PM
01/12/09 02:45 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
I also vote for kroil. That stuff is magical. Better than or
Re: Stuck 383? [Re: Mr.Runum] #190968
01/12/09 08:28 PM
01/12/09 08:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Re: Stuck 383? [Re: BSB67] #190969
01/12/09 09:27 PM
01/12/09 09:27 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
The winner is AERO KROIL . That is what I started with yesterday after getting down to just the short block. Things were tight. Let set over night, came home from work and sprayed down again, then after dinner away I went. Some of the pistons came out like they were in butter . Got all eight out with out any damage to the block or crank. Journals all looked good as did the cylinders. It looked like they had taken the intake and exhaust manifolds off and turned up on end and the oil had moisture and turned to sludge. Now I have a good 68 383 and steel crank for sale.
Thanks for all replys.
Re: Stuck 383? [Re: Mr.Runum] #190970
01/12/09 09:31 PM
01/12/09 09:31 PM
that stuff must be something else, I'm gonna have to try it.
Re: Stuck 383? [Re: RapidRobert] #190971
01/12/09 10:12 PM
01/12/09 10:12 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Its like $14.00 a can...
It works because it is molecularly (is that a word?) smaller than most other penetrants. This allows it to creep into the smallest places most other penetrants cant.
My mother in law worked for them at one time.
Friend of mine had a pair of matching AFB carbs that had been stuck for a decade or more. He had tried soaking them in a tub of WD 40, and a host of other oils and penetrants. Finally he gave up. Few years later I gave him a can of kroil....one can. Sat over nite, and they freed right up.
Re: Stuck 383? [Re: NTOLERANCE] #190972
01/12/09 10:16 PM
01/12/09 10:16 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
You know I haven't even heard of that before until I went to work for Modine. They use it like it's going out of style. I've got a 440 stuck at the moment. I'm needing to get it apart. I'll probably try it, I never even thought about it before.
Moparlee
Re: Stuck 383? [Re: NTOLERANCE] #190973
01/14/09 12:40 AM
01/14/09 12:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm still find this hard to believe , we had it at work and it SUCKED , WD 40 worked as good if not better .
Re: Stuck 383? [Re: JohnRR] #190974
01/14/09 07:25 PM
01/14/09 07:25 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
I had never heard of KRIOL before a recent job change. I have used it on many thing that WD-40 would not touch with great success. It is by far the best penatrating oil that I have ever used.
Re: Stuck 383? [Re: JohnRR] #190975
01/14/09 08:11 PM
01/14/09 08:11 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Well then, youre the first person I have ever heard say it didnt work. After two decades in mechanical/maintenance, youre the only one.
Re: Stuck 383? [Re: NTOLERANCE] #190976
01/14/09 08:23 PM
01/14/09 08:23 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I've unstuck about 5 motors over the years using automatic transmission fluid. Pour some in each cylinder and let it sit for about a week. Then go back and moved the crank back and forth until it breaks free. It worked every time for me.
Re: Stuck 383? [Re: NTOLERANCE] #190977
01/15/09 10:24 AM
01/15/09 10:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Aero Kroil....
I tried it on a stuck AVS , how many years do you have to leave the carb in there ? I left one in for a MONTH , it's STILL stuck SOLID
Re: Stuck 383? [Re: JohnRR] #190978
01/15/09 11:08 AM
01/15/09 11:08 AM
WA 98043
thecarfarmer Offline
WA 98043
Put me on the Kroil bandwagon.
I used to buy my own and keep it in my toolbox, even though the shops I worked at stocked WD-40, CRC, Seafoam, or some other stuff.
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
