Can you identify these early hemis with these #s? #1907217
09/06/15 12:00 AM
09/06/15 12:00 AM
Missouri
MOBodyman Offline OP
Missouri
Numbers are from 2 different motors.
BTW, these are early hemis, if that helps..
TIA
Dallas
11948142_10153474168666413_751742258_n.jpg11995667_10153474168156413_1163411651_n.jpg
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1907371
09/06/15 11:58 AM
09/06/15 11:58 AM
moparx Offline
moparx  Offline
13233259 : casting # for 51-54 331ci. chrysler. this appears to be a 54 block because it looks like a non-extended bell block as used in 51-53.
cwc : chrysle windsor canada foundry
D502 - 10361 : D502 = 241ci. dodge car, 54 modle year
10360 = engine # built [not entirely sure on this]
member trwaters is an early hemi expert. maybe he will see this post and comment. hope this helps some.
beer
Re: Can you identify these motors with these #s? [Re: moparx] #1908378
09/07/15 11:49 PM
09/07/15 11:49 PM
Missouri
Missouri
beer
Thanks for the reply. Unfortunately the 331 is evidently an early model. Here are some more pics. It has the extended bell housing. Can it even be used for anything?
Dallas
11998659_10153474168636413_533414855_n.jpg11998471_10153474168591413_2055447116_n.jpg11998016_10153474168771413_1044119394_n.jpg11936977_10153474168741413_1650678439_n.jpg
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908383
09/07/15 11:55 PM
09/07/15 11:55 PM
Missouri
Missouri
Here are some pics of the other one. Are these just conversation pieces or are they usable for anything? A friend inherited them and doesn't know anything about these..(neither do I obviously).
I'm trying to give him some info so he can decide what to do with them.
Thanks again,
Dallas
11923277_10153474167906413_201121219_n.jpg11949738_10153474168141413_1587073317_n.jpg
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908396
09/08/15 12:07 AM
09/08/15 12:07 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://classichemi.com/index1.shtml
Look here. Might be listed.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908410
09/08/15 12:24 AM
09/08/15 12:24 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Those are in rough shape to say the least. not worth much. I hate to say that. Cool but not worth much more than scrap.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908415
09/08/15 12:39 AM
09/08/15 12:39 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi ,
extended bell not a problem , just machine it off and retap !
look bad but prob some good parts there block ,crank , heads , sheet metal ect .!
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908419
09/08/15 12:44 AM
09/08/15 12:44 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Based on the exhaust I'd guess one is from an industrial application (pump engine etc.). As mentioned, those look WAY rusty from weather, I'd be surprised if they aren't frozen up tight. If not maybe salvageable to build, if not probably good for parts, either way $300-$600.00ish would be my value guess. Some guys will go as far as milling off the extended bell versions to adapt a standard bell housing but it's a lot of work and expense to salvage a 331.
.02
Re: Can you identify these motors with these #s? [Re: ScottSmith_Harms] #1908467
09/08/15 02:50 AM
09/08/15 02:50 AM
Missouri
Missouri
Found out a little more info. The 331 may have came off of an irrigation pump.
I agree, they look pretty bad to me. Too bad the guy didn't take better care of them. He had them for a long time. I feel bad for his son. I think he was hoping they would be worth something..
Thanks all,
Dallas
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1908503
09/08/15 08:40 AM
09/08/15 08:40 AM
moparx Offline
moparx  Offline
sorry i mis-identified that extended bell block. i just guessed the first picture was of the rear edge of the block and not the inspection/vent hole of the extended version.also, as has been mentioned,there may be[and probably are] usable parts on both engines, but until both are disassembled, the best bet would be to proceed as if they are nothing more than yard/garage art.
beer
Re: Can you identify these motors with these #s? [Re: moparx] #1908567
09/08/15 12:28 PM
09/08/15 12:28 PM
dogdays Offline
dogdays  Offline
There's a shorty bellhousing adapter for the '53 motor. No machining necessary.
I agree they have some value, the $300 - 600 guess is good, I think.
R.
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1909824
09/10/15 11:57 AM
09/10/15 11:57 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It freezes in Missouri. I assume it has rained in the engines and frozen. Looks like shop decorations to me.
2011 Drag Pak Challenger
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1910127
09/10/15 08:23 PM
09/10/15 08:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Intact, I would bet your looking at scrap weight. Maybe more if you find someone looking for parts. Pull the valve covers and rocker gear if its any good, maybe exhaust manifolds if they are not cracked, those items sell pretty good, especially if you clean them up and paint the covers. They make great wall art, and that's probably where the value will be. The rest of the stuff you will be lucky to give away!
If you find someone waving $300 in your face, grab it before they change their mind. You probably won't get that much from them out of parts. Gene
Re: Can you identify these motors with these #s? [Re: MOBodyman] #1911074
09/12/15 01:44 PM
09/12/15 01:44 PM
Missouri
Missouri
Thanks for the replies. I passed the info on to him.
Dallas
