2 step question #1902961
08/31/15 04:07 AM
08/31/15 04:07 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
when using a 2 step on a auto trans BUT NO transbrake is it better to mat the throttle or not fully allowing for some accelerator pump shot ?
been a long time since I used one , never ran it long enough to try .
I am aiming for a more consistent light . I know everyone says go a brake but that is a big spend .Hoping the 2 step might give me some of that consistency .
I do have the 2 step button mounted on my brake pedal above the pad
any thoughts welcome
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 2 step question [Re: tex013] #1903062
08/31/15 12:01 PM
08/31/15 12:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would depend on the launch rpm... if you use a
low rpm then you would need the pump shot.. if high
rpm you have the air flow going already
wave
Re: 2 step question [Re: tex013] #1903088
08/31/15 12:54 PM
08/31/15 12:54 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
If you mat it What rpm are you setting the 2 step?
Will the brakes hold it on the line? I think you will have to test to find out what works best.
Don
Re: 2 step question [Re: cudadon] #1903371
08/31/15 07:28 PM
08/31/15 07:28 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Are you running in a electronics class? Around here we either run in Pro class (electronics/ Trans brake/ 2 step) or Foot brake class( no electronics of any kind, trans brake or 2 step).
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 2 step question [Re: tex013] #1903383
08/31/15 07:40 PM
08/31/15 07:40 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
ok ,
I will be leaving 2200-2600 . that's all I can hold the brakes at easily .
the class allows transbrake and 2 step . no delay box .
looks like more testing
thanks guys
Tex
New best MPH 130.32
Re: 2 step question [Re: tex013] #1907435
09/06/15 01:57 PM
09/06/15 01:57 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Originally Posted By tex013
ok ,
thanks guys
Tex
I'm not sure if 2200-2600 will be enough rpm that you won't need some pumpshot when it comes off the 2 step.
By cutting the engines torque while on the 2 step you MAY be able to go higher rpm than normal. Again testing is the key!
You will have to find your "spot" on the starting line to know if you need more or less 2 step rpm for your reaction times.
Don
Re: 2 step question [Re: tex013] #1907585
09/06/15 07:36 PM
09/06/15 07:36 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks
Don
New best MPH 130.32
Re: 2 step question [Re: tex013] #1907661
09/06/15 10:08 PM
09/06/15 10:08 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I left @ 2150 on the 2 step. No problems.
Re: 2 step question [Re: Leigh] #1907675
09/06/15 10:26 PM
09/06/15 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was your foot on the floor.. thats pretty low rpm/ air flow to
get away with no more pump shot..
..to the OP... you may have to
roll the pedal up to and just above the 2 step rpm so you still
have a pump shot left... might even need a 50cc pump.. your gonna
have to test
wave
Re: 2 step question [Re: MR_P_BODY] #1907694
09/06/15 10:39 PM
09/06/15 10:39 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yes, on the tin. 4 wheel line loc, MSD 6T, soft touch, 2 step and RTD 6. I made my own rpm modules. Super consistant 11.50 Super Pro setup. I used a R4781, R3310 and 80496. All three worked flawless.
Re: 2 step question [Re: MR_P_BODY] #1907734
09/06/15 11:15 PM
09/06/15 11:15 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
MrPeabody,
that is what I am going to try . I do have 50cc pumps on my carb .
Just no enough T&T here
Tex
New best MPH 130.32
Re: 2 step question [Re: tex013] #1907735
09/06/15 11:19 PM
09/06/15 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
MrPeabody,
Tex
I am talking a 50cc pump on the primary side... then you might
need it on the secondary side also... I didnt do much foot brake
racing because I couldnt hold it on the brakes on the line but
my engine needed a lot of fuel on the hit
wave
Re: 2 step question [Re: tex013] #1907775
09/07/15 12:35 AM
09/07/15 12:35 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
both pumps are 50cc now
I better get at it
Tex
New best MPH 130.32
Re: 2 step question [Re: tex013] #1907781
09/07/15 12:41 AM
09/07/15 12:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I better get at it
Tex
Remember to play with squirters and the pump cam
wave
Re: 2 step question [Re: tex013] #1907811
09/07/15 01:43 AM
09/07/15 01:43 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
I've set mine between 1800-2300 worth my foot to the floor with no problem. Mallory hi fire ignition. 12.00 smallblock. Like others said, you're just gonna have to try it out.
"I'm not a Gynecologist, but I'll take a look."
