2-stage dry sump street strip question? #190659
01/11/09 05:23 PM
01/11/09 05:23 PM
mass,usa
sickhemi Offline OP
sickhemi  Offline OP
mass,usa
hello is it ok to run a two stage dry sump one pressure stage and one suction stage for street strip use?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: 2-stage dry sump street strip question? [Re: sickhemi] #190660
01/11/09 05:55 PM
01/11/09 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know of guys running them on the street(limited
mileage), but it was just a external pump but you
are talking a holding tank on your... right. Either
way its just the belt thats the issue
Re: 2-stage dry sump street strip question? [Re: MR_P_BODY] #190661
01/11/09 06:26 PM
01/11/09 06:26 PM
mass,usa
sickhemi Offline OP
sickhemi  Offline OP
mass,usa
yup 8qt holding tank. also could you use a hv pump with bottom feed milodon pump cover and pickup for the suction side to the dry sump tank and feed the engine with a single stage belt driven pressure stage?
Re: 2-stage dry sump street strip question? [Re: sickhemi] #190662
01/11/09 06:53 PM
01/11/09 06:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont see why not, but I wouldnt see why you would,
most of the time you are trying to shorten the pan
or get rid of the pick up to go to that style of a system
Re: 2-stage dry sump street strip question? [Re: MR_P_BODY] #190663
01/12/09 10:28 PM
01/12/09 10:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Either
Not sure I can fill in the blanks here, are belts that unreliable or what for street use?
Re: 2-stage dry sump street strip question? [Re: jcc] #190664
01/12/09 10:36 PM
01/12/09 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Either
Its just the posibility(small in my mind) that something
will cut/break the belt. A sheild would do wonders
