Torqueflite 2-3 overlap #1906381
09/04/15 04:29 PM
09/04/15 04:29 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Been working on my 1970 torqueflite for a while now. I finally got my shift point issue resolved but have overlap on the 2-3 shift. I've had the valve body out and cleaned it. At some point someone installed a 5.0 kickdown lever and the trans also has a controlled load kickdown servo (1971 and later style). I've got line pressure screw adjusted to 1 and 3/16" and the front band to 72 in/lbs and backed off 1.5 turns since it has the 5.0 lever. I pulled out the servo while in there and was going to put a blocker tube in it in place of the small inner cushion spring but it already had a thicker washer that acts as a blocker and the spring had been removed. Besides yanking the trans and switching the lever is there anything I can do with pressure or band adjustment to help with the overlap?
1970 EK2 T/A 727
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906389
09/04/15 04:41 PM
09/04/15 04:41 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 5.0 lever is your problem , you don't want to lower the pressure and changing the band adjustment may not change it enough.
Sadly the fix is to change the lever , 3.8 or a 4.2.
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906431
09/04/15 05:47 PM
09/04/15 05:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
When I do a trans in something I plan to tweak stuff in I drill a big hole near the plug for the band anchor so I can switch the lever in the car, works great and even the fat factory converters seem to have enough room (barely). You could probably do it with the trans in the car just don't drill into the converter.
Re: Torqueflite 2-3 overlap [Re: HotRodDave] #1906492
09/04/15 07:54 PM
09/04/15 07:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 5.0 lever was factory installed in several transmissions and they didn't suffer from severe overlap.
The 5.0 lever, itself, isn't the bad guy, the combination of that lever and the rest of the trans setup is. It would be easier to pull the valve body and place a restrictor orifice in the front clutch circuit than to try to change the lever in situ. It there's already a restrictor in place go smaller.
Simply loosening the kickdown band adjustment is the easiest option.
Re: Torqueflite 2-3 overlap [Re: John_Kunkel] #1906497
09/04/15 08:10 PM
09/04/15 08:10 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I'll agree...
Have had a 5.0 lever in a 'kitted' TF for many moons...
Shifts are fine...
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906509
09/04/15 08:43 PM
09/04/15 08:43 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I wouldn't say it's severe but it is annoying especially now I have my shifts timed right. Restrictor orifice seems like a good approach where can I get one and what size(s)do I need? I did notice when I lowered pressure at one point the overlap was less, but the 1-2 was softer. A 5.0 lever may work fine for some, but it is prone to overlap and that's what I have and I need to find a way to compensate and eliminate it.
1970 EK2 T/A 727
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906541
09/04/15 09:49 PM
09/04/15 09:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The 2-3 overlap is a pet peeve of mine and I have done a bunch of the restrictors. Some guys use brass pipe plugs after threading the orifice. I use a 3/8 core plug (like a mini freeze plug). Dorman #555-115. You may have to drill the orifice a bit to get the plug in.
On a street car, it is difficult to get ALL the slap out when idling around town. Light load and low speed reveal the slap from 2 to 3 the most. If you want it all out on a street car, the best way is to start with a small hole in the plug (.070" or so usually) to the point that there is a flair up between the 2-3 shift. Then keep opening up the hole until the flair up just stops. But that requires repeated dropping of the valve body. That is the way I do mine; start small enough to have a flair up and gradually get larger till there is no flair under load and little or no slap at light load, low speed.
For those that do not particularly want to repeatedly drop the valve body, .090" will usually get you close. But it does vary a little from tranny to tranny.
At the risk of getting flamed, I will make a suggestion should you decide to start with a small hole and gradually work your way up. I just put some stiff grease on the drill bit each time I go a bit larger and just leave the same plug in the orifice. Then, spray a good amount of carb cleaner or brake clean or similar product and then hit the plug with some air. Gets the chips out for me.
If you do need to pull the core plug, you can just screw in a sheet metal screw and pull the plug with a claw hammer or something similar.
All it takes is some time and patience to get all (or most) of the 2-3 overlap out.
Master, again and still
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906692
09/05/15 02:18 AM
09/05/15 02:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I like using the "oversize" billet front servo kit with the "O" ring servo cover. Also, the 3.8 or 4.2:1 lever.
Re: Torqueflite 2-3 overlap [Re: 451Mopar] #1906724
09/05/15 04:36 AM
09/05/15 04:36 AM
Dave that was good stuff. I was thinking that a guy (on here) once drilled/tapped for carb jets so he could get the flow spot on that way
Re: Torqueflite 2-3 overlap [Re: f2502011] #1906918
09/05/15 03:00 PM
09/05/15 03:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You stated that the front servo piston already had blocker installed (part of a shift kit) so the trans might also have a restrictor orifice installed. Before tearing into it try backing the band adjustment off to 2 or 2 1/4 turns.
As stated earlier, overlap is more pronounced at low speed low throttle so, if there is no noticeable overlap at WOT, you might be better off just living with it at low speeds.
The fancy billet servo pictured above would likely exacerbate overlap woes.
Re: Torqueflite 2-3 overlap [Re: John_Kunkel] #1906948
09/05/15 03:45 PM
09/05/15 03:45 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I was just in the trans and took lots of pics. No restrictor was there. I had the KD band at 2 turns off before I saw the 5.0 lever and did 1.5 since that is the recommendation for it. When it was 2 turns it still had the overlap. The only thing that minimized the overlap was lowering the line pressure but when I did that it made the 1-2 softer too.
1970 EK2 T/A 727
Re: Torqueflite 2-3 overlap [Re: DaveRS23] #1906997
09/05/15 05:52 PM
09/05/15 05:52 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I've also read about tapping the hole with 1/8 npt and using a threaded hex head brass plug, but I'm not sure where to get one of these brass plugs. Any suggestions on that? Also, I noticed one of the transgo kits comes with a restrictor with a 0.140 hole so I'm wondering if 0.070 - 0.090 may be too small or too restrictive??
1970 EK2 T/A 727
Re: Torqueflite 2-3 overlap [Re: f2502011] #1907032
09/05/15 06:44 PM
09/05/15 06:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How many springs are in the drum? Use all 15 that'll slow the overlap. I don't like the idea of a .090 hole keeping the high clutch applied.
I use the 3.8 lever with 10-12 springs so I don't have to adjust the band so often, of course that means removing trans
Re: Torqueflite 2-3 overlap [Re: cudaman1969] #1907081
09/05/15 08:03 PM
09/05/15 08:03 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The size of the restrictor hole does not affect the pressure to the clutch, only the amount of time it takes to fill the area behind the apply piston. The larger the hole, the faster it fills but the pressure will equalize on both sides of the restrictor at some point.
Re: Torqueflite 2-3 overlap [Re: cudaman1969] #1907085
09/05/15 08:07 PM
09/05/15 08:07 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
shruggy on the spring count.
It would be great if I had the 3.8 or 4.2 lever, but I don't so I need to see if and what I can do to see if I can make the current configuration work. Would be different if I had a lift and a trans-jack, then it wouldn't be that big of a deal to pull it and swap out the parts, but I don't.
1970 EK2 T/A 727
Re: Torqueflite 2-3 overlap [Re: f2502011] #1907088
09/05/15 08:11 PM
09/05/15 08:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Most of the better hardware stores should have a selection of brass pipe plugs, of course you'll need one with the recessed allen head rather than the square head. But the 3/8 core plug works just as well and is easier to use, so it is the only way I do it anymore.
The .140 doesn't usually have much impact. I have changed a bunch of them out. And the only impact I have ever seen by going with the smaller opening is that it addresses the 2-3 overlap. No other issues. And since it is completely reversible, there is not any real reason not to go with the opening size that eliminates the overlap.
Re: Torqueflite 2-3 overlap [Re: PC-CHARGER] #1907117
09/05/15 09:01 PM
09/05/15 09:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
As long as the seals and rings are tight so as no pressure loss, the trans don't seal up that good anyway, always fluid loss, pump cavitation on acceleration, things like that, I like volume plus pressure.
To the op, never had a lift or trans jack, just jack stands, floor jack and muscles. Two hours or less on the bench. It's all procedure. If you want something done you gotta do it.
Re: Torqueflite 2-3 overlap [Re: f2502011] #1907347
09/06/15 10:45 AM
09/06/15 10:45 AM
moparx Offline
moparx  Offline
brass hex head plugs are best, but somewhat hard to find. i use the standard plated steel versions. you are not really cranking them super tight, and as they are always covered with atf, i have never had a problem with removing them. if you pm me with your address, i'll send ya a few to experiment with, no charge.
beer
Re: Torqueflite 2-3 overlap [Re: f2502011] #1907384
09/06/15 12:48 PM
09/06/15 12:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The threaded aluminum plugs are pretty easy to find and drill.
Re: Torqueflite 2-3 overlap [Re: 451Mopar] #1907412
09/06/15 01:18 PM
09/06/15 01:18 PM
X2 X2 on the drilling! I just drilled a .015" hole in an iron 3/8 NPT plug to go in the back end of the pass SB horizontle oil gallery for a mini pressurized squirt of oil onto the intergear/cam gear mesh. No mas. alum next time. speedway mtrs if you have time for mailorder or you could source em local
