What fluid to use in A833 manual transmission? #634286
03/08/10 06:29 PM
03/08/10 06:29 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
The Chrysler service bulletin says Type F or Type FA automatic transmission fluid...is that what you guys use?
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #634287
03/08/10 06:53 PM
03/08/10 06:53 PM
Port Hope, Ontario
TheMoparJunky Offline
mopar addict
mopar addict
Port Hope, Ontario
Racers back in the day used it I think because of the heat transfer, fluid compaction(none) and high viscosity rather than the thick sludgy, stinky straight 80 or 90.
Because it is a gear box, I would recommend straight 80(The same for the diff.).
Like all petroleum products after heated up to temp. it will become very viscous so there won't be as much "Fluid/power loss". The dynamic seals will not act differently with either.
The Mopar Junky
Back off the Mopar bandwagon- Wannabe Millwright Enjoying the fat lazy unemployed life
Re: What fluid to use in A833 manual transmission? [Re: TheMoparJunky] #634288
03/08/10 06:56 PM
03/08/10 06:56 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Use 90 weight gear oil,my friend did what the book said,and it cost him two 4 speed transmissions. The front bearing in one came out in peices. ATF may be ok in northern Alaska,but not down here.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: What fluid to use in A833 manual transmission? [Re: chargervert] #634289
03/08/10 07:04 PM
03/08/10 07:04 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
use the ATF recomended by Mopar. Thats what was in that tranny when new. It's worked fine for 40 years. Mopar knows better what to use seeing they designed it. I've had plenty of 4 speeds and never a failure due to fluid.
Re: What fluid to use in A833 manual transmission? [Re: Dougsmopars] #634290
03/08/10 07:29 PM
03/08/10 07:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
90 weight gear oil
Re: What fluid to use in A833 manual transmission? [Re: DAYCLONA] #634291
03/08/10 11:15 PM
03/08/10 11:15 PM
IN
ahy Offline
ahy  Offline
IN
At different times MOPAR recommended both ATF and gear oil. The ATF mostly for cold weather areas. Unless you're driving often in 0 degree weather with it I would suggest gear oil. I do believe it provides better protection.
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #634292
03/08/10 11:44 PM
03/08/10 11:44 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
atf-dextron not type f for manuels 1/4 - 1/2 " below fill plug hole !
over fill it and a hot day it expands a little and may be forced out the vent !
Re: What fluid to use in A833 manual transmission? [Re: calrobb2000] #634293
03/09/10 12:02 AM
03/09/10 12:02 AM
Dougsmopars Offline
Dougsmopars  Offline
Just looked at my 69 mopar shop manuel. SAE 140 for warm climate. SAE 80 or 90 or ATF fluid for cooler climate. So if you live in Florida use SAE 140 if you live in Michagin use ATF. If your in the middle guess. I'm in New England. All the 4 speeds i've had were full of ATF when i drained them and i never had any problems. Every couple of years i changed the fluid and they always worked fine.
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #634294
03/09/10 01:23 AM
03/09/10 01:23 AM
myself I'd 1st start w gear oil for the wear protection offered by the "extreme pressure" formulation/additives and if it will work for you as in the shifting quality is acceptable then I would stay with it & if not try
ATF.
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #634295
03/09/10 01:37 AM
03/09/10 01:37 AM
IMGTX Offline
IMGTX  Offline
I used to use ATF in Winter and 90wt in summer. Very often a blend of the two.
Now Passon has his own formula out that I want to try.
It ought to be worth it.
Re: What fluid to use in A833 manual transmission? [Re: IMGTX] #634296
03/09/10 01:48 AM
03/09/10 01:48 AM
Now Passon has his own formula out that I want to try.It ought to be worth it.
Now that you mention it several poeple have posted that they were very happy w Passons' lube
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1905990
09/03/15 11:25 PM
09/03/15 11:25 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I ran an 80 OD833 in my 81 short bed that had ATF in it when I got it and I ran it like that for 10 years and it's it still works fine.
Moparlee
Re: What fluid to use in A833 manual transmission? [Re: Robbins] #1906012
09/03/15 11:41 PM
09/03/15 11:41 PM
IN
ahy Offline
ahy  Offline
IN
As mentioned, ATF tended to be recommended for cold weather and 90 weight or heavier gear lube for hot. Common GL5 gear lube is not friendly to syncros. For 3 season use, suggest SAE 90 GL4 gear lube (hard to find), better yet Redline MT90 gear lube or the Passon fluid. Redline MTL for cold weather.
It does not seem that current ATF formulations are friendly to MT applications and I think the 833 likes a heavier lube.
Re: What fluid to use in A833 manual transmission? [Re: Robbins] #1906020
09/03/15 11:47 PM
09/03/15 11:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Resurrecting a 5 year old thread?
Don't be the exception.
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1906032
09/03/15 11:55 PM
09/03/15 11:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I only use gear oil in mine for over 30 years.
Don't fall into the ATF crowd tsk They just haven't had one apart that ate the cluster because ATF doesn't lube well enough for your car. You run your car hard and it needs the correct lube. The guys that say it's OK either have low horsepower or don't whoop on them twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1906092
09/04/15 01:05 AM
09/04/15 01:05 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Tractor gear oil, GL3 or GL4.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1906094
09/04/15 01:10 AM
09/04/15 01:10 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I'm a gear oil kinda guy myself, never felt good about ATF in a gear box. twocents
Careful, your character's showing!
Re: What fluid to use in A833 manual transmission? [Re: mopar346] #1906098
09/04/15 01:16 AM
09/04/15 01:16 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I first saw ATF in Mopar stick trannys in 1963. It held up fine in my three speed stick drag cars and Muncie transmissions to.
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1906104
09/04/15 01:27 AM
09/04/15 01:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with Gus.I bought my 65 in 69.The 4speed had gear oil from the factory.Still has gearoil after all these years.Oh yeah it was a daily driver everday for at least 5 years.Ohio winters are cold and never a problem shifting.Rocky
Chrysler Firepower
Re: What fluid to use in A833 manual transmission? [Re: dustergirl340] #1906234
09/04/15 12:01 PM
09/04/15 12:01 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
80-90 weight gear oil
