Re: What fluid to use in A833 manual transmission?
[Re: dustergirl340]
#634287
03/08/10 06:53 PM
03/08/10 06:53 PM
Posts: 521 Port Hope, Ontario
TheMoparJunky
mopar addict
mopar addict
Port Hope, Ontario
Racers back in the day used it I think because of the heat transfer, fluid compaction(none) and high viscosity rather than the thick sludgy, stinky straight 80 or 90. Because it is a gear box, I would recommend straight 80(The same for the diff.). Like all petroleum products after heated up to temp. it will become very viscous so there won't be as much "Fluid/power loss". The dynamic seals will not act differently with either.
The Mopar Junky
Back off the Mopar bandwagon-
Wannabe Millwright
Enjoying the fat lazy unemployed life
[Re: TheMoparJunky]
#634288
03/08/10 06:56 PM
03/08/10 06:56 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Use 90 weight gear oil,my friend did what the book said,and it cost him two 4 speed transmissions. The front bearing in one came out in peices. ATF may be ok in northern Alaska,but not down here.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Dougsmopars]
#634290
03/08/10 07:29 PM
03/08/10 07:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: dustergirl340]
#634292
03/08/10 11:44 PM
03/08/10 11:44 PM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi atf-dextron not type f for manuels 1/4 - 1/2 " below fill plug hole ! over fill it and a hot day it expands a little and may be forced out the vent !
[Re: dustergirl340]
#634294
03/09/10 01:23 AM
03/09/10 01:23 AM
RapidRobert
myself I'd 1st start w gear oil for the wear protection offered by the "extreme pressure" formulation/additives and if it will work for you as in the shifting quality is acceptable then I would stay with it & if not try ATF.
[Re: dustergirl340]
#1905990
09/03/15 11:25 PM
09/03/15 11:25 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I ran an 80 OD833 in my 81 short bed that had ATF in it when I got it and I ran it like that for 10 years and it's it still works fine.
Moparlee
[Re: Robbins]
#1906020
09/03/15 11:47 PM
09/03/15 11:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I ran an 80 OD833 in my 81 short bed that had ATF in it when I got it and I ran it like that for 10 years and it's it still works fine. Resurrecting a 5 year old thread?
[Re: dustergirl340]
#1906032
09/03/15 11:55 PM
09/03/15 11:55 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I only use gear oil in mine for over 30 years. Don't fall into the ATF crowd They just haven't had one apart that ate the cluster because ATF doesn't lube well enough for your car. You run your car hard and it needs the correct lube. The guys that say it's OK either have low horsepower or don't whoop on them Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dustergirl340]
#1906092
09/04/15 01:05 AM
09/04/15 01:05 AM
Posts: 543 Indiana, Just Off I-70
BradD
Tractor gear oil, GL3 or GL4.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: mopar346]
#1906098
09/04/15 01:16 AM
09/04/15 01:16 AM
Posts: 1,821 South Bend
John Brown
South Bend
I first saw ATF in Mopar stick trannys in 1963. It held up fine in my three speed stick drag cars and Muncie transmissions to.
[Re: dustergirl340]
#1906104
09/04/15 01:27 AM
09/04/15 01:27 AM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
I agree with Gus.I bought my 65 in 69.The 4speed had gear oil from the factory.Still has gearoil after all these years.Oh yeah it was a daily driver everday for at least 5 years.Ohio winters are cold and never a problem shifting.Rocky
Chrysler Firepower
