Torque Converter stall speed #1903910
09/01/15 12:36 PM
09/01/15 12:36 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
A question related towards torque converter stall speed.
In a three speed trans (727). Should the stall speed be at the maximum torque RPM when attempting to accomplish the fastest ET/MPH in the 1/4 mile?
Re: Torque Converter stall speed [Re: B5496RR] #1903917
09/01/15 12:41 PM
09/01/15 12:41 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have always had good luck with the convertor flash being 200-300 rpm over max torque rpm.
IE..... If max torque is at 5200, try to set the convertor up to flash at 5400-5500
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Torque Converter stall speed [Re: B5496RR] #1904152
09/01/15 03:29 PM
09/01/15 03:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My 8" was flashing at 5800 which was right around the area of peak tq. Just got it back from Ultimate and should be right around 6k. Data recording was showing a small dip in eng rpm on the initial hit.
Re: Torque Converter stall speed [Re: B5496RR] #1904172
09/01/15 04:02 PM
09/01/15 04:02 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
B3422W5 - Thanks for the fast response. Always good, clear and concise info from you!
J_Body - Are you stating that your converter is now hopefully setup to flash/stall at peak TQ?
Thanks for the replies
Re: Torque Converter stall speed [Re: B5496RR] #1904302
09/01/15 06:51 PM
09/01/15 06:51 PM
gregsdart Offline
gregsdart  Offline
I have had good luck going loose over the years. When the air goes away and engine torque is down the lose converter is still up in the best rpm area for overall performance. Another advantage is that if there is a touch of tire slippage the converter stall is dragged down a bit but is still above peak torque and actually works a bit harder ( starts to lock up) making the car more consistent with less loss of acceleration. A rough rule of thumb is 1100 to 1300 rpm from stall rpm to shift point .
Re: Torque Converter stall speed [Re: B5496RR] #1904544
09/01/15 11:16 PM
09/01/15 11:16 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
on numerous data recordings we had a "stall" at launch which was determined the converter dragging the engine down too much. Dyno peak torque was 5700-5800 so we loosened the stall speed some. should be at or a little above 6K now, which will probably change again when we go from the 4.30 gear to a better suited 4.88. Higher numerical gear will help get the weight going easier, which can also have an effect on stall speed too as the engine isn't having to work as hard. In other words I've been overwhelmed with information, but am trying to use it as best as I can to optimize what I've got.
Re: Torque Converter stall speed [Re: J_BODY] #1904557
09/01/15 11:26 PM
09/01/15 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its gonna matter how much torque is at that RPM... big torque
wont pull down like a lesser torque engine.... then weight is
the other factor
wave
Re: Torque Converter stall speed [Re: B5496RR] #1904828
09/02/15 12:48 PM
09/02/15 12:48 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
Excellent info and feedback!
Thank you!
