1970 & 1971 29944450 15 x 7 Steel Wheels #1903590
09/01/15 12:18 AM
09/01/15 12:18 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm doing a bit of wheel research. If you own or have good photos of someone else's wheels please post pictures of the valve stem areas with the dates, part#'s, and plant info stampings. Also, the plant stampings on the hub center areas.
Also, have any of you ever seen an original lacking the Pentastar stamping?
Here are a few shots to get things going.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903592
09/01/15 12:21 AM
09/01/15 12:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903656
09/01/15 02:11 AM
09/01/15 02:11 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Original 1970 paint...take-offs when Challenger 440 was new.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903658
09/01/15 02:13 AM
09/01/15 02:13 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
2
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903661
09/01/15 02:19 AM
09/01/15 02:19 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
EL5, thanks, can you post closer pics of the back sides of the centers?
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903689
09/01/15 03:38 AM
09/01/15 03:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Scott - I have 7 so I'll try get you some pics when I get state side
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903865
09/01/15 11:50 AM
09/01/15 11:50 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Hi Scott, yep I can post more of the back sides and inside bead areas as soon as my son shows me how to reduce the giant sized pics i have. I even have a close up of the markings on the original valve stems. (the side you don't see inside the rim). Cool stuff.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1903872
09/01/15 11:55 AM
09/01/15 11:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool, any pics appreciated. I'm looking to document manufacturing dates, assembly plant info, and anything oddball. I'll post more of my own later.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1904194
09/01/15 04:21 PM
09/01/15 04:21 PM
CA
cudino Offline
cudino  Offline
CA
Hi Scott,
I have 4 sets of 450 wheels, each set with matching datecodes:
- One set of 4 with 12-11-69 dates
- One set of 4 with 9-25-70 dates
- A second set of 4 also with 9-25-70 dates
- One set of 4 that are hard to read, but I think they are 9-30-70. On all 4 of these wheels they seem to have a line over the top of the '9', very faint but on all 4 wheels.
Here's pictures of one wheel from each set.
- Wade
450 wheel dates -70 Hemicuda convert.JPG450 wheel date -71 Hemicuda EV2.JPG450 wheel date -71 Hemicuda FC7.JPG450 wheel date -71 Hemicuda convert.JPG
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1904255
09/01/15 05:57 PM
09/01/15 05:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Exellent pics, thank you Wade!
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1915844
09/19/15 08:32 PM
09/19/15 08:32 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
12-2-69 Wheel
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1915847
09/19/15 08:33 PM
09/19/15 08:33 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Another 12-2-69 Wheel
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1915848
09/19/15 08:34 PM
09/19/15 08:34 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
9/25/70
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1915850
09/19/15 08:35 PM
09/19/15 08:35 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
12/2/1969
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1915951
09/20/15 01:22 AM
09/20/15 01:22 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Morty!
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1916068
09/20/15 12:45 PM
09/20/15 12:45 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
A few shots of mine, after bead blasting.
What's interesting is the incomplete "0" stamp by the valve stem, almost looks like a "1".
The "0" stamp on the inside rim confirmed it was a '70 wheel.
Regarding the purple wheels off the '70 Challenger posted above, was it common or possible to have a date code spread that far off the same car?
Not questioning, just curious.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1916070
09/20/15 12:46 PM
09/20/15 12:46 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Another of the hub.
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1916335
09/20/15 09:45 PM
09/20/15 09:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
bill440rt
Very late date code, and I don't believe that's an incomplete "0" it's a 1. I've seen it before (the hub and the hoop dates being different) the date by the valve stem is the latest date as it is the final assembly date of the wheel assembly. Is there a pentastar after the date? I don't see one? Do you have a set of 4 of those? Are they known to be original to your car?
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1916387
09/20/15 10:59 PM
09/20/15 10:59 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
bill440rt
I only know what I was told by the fella who sold them to me. He purchased the Challenger new and installed a mags right away he said. I've never seen a set that were six weeks apart either before this set but they were matching in every way other than the dates. Hey I guess ya never know. Some rims could be stamped and sitting around and then car could have been assembled in Feb. 1970....who knows. I owned a 1971 Charger R/T 440 Sixpack with a G for 1971 stamped right over the top of the F for 1970 on the machined pad near distributor. Found out that it was more common on Hemis but occasionally RB engine long blocks would sit and get restamped for the next year. The nice part about that engine was that since it was actually a 1970 440 Sixpack long block assembly it had a slightly hotter cam profile than a G coded 1971 unit. Pretty cool....thanks for letting it sit for the extra months. smile
Re: 1970 & 1971 29944450 15 x 7 Steel Wheels [Re: ScottSmith_Harms] #1916421
09/20/15 11:23 PM
09/20/15 11:23 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Deleted
