Dana 70 crush sleeve ??? #1904109
09/01/15 02:52 PM
09/01/15 02:52 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Does the Dana 70 used in the 2nd gen rams with a cummins use a crush sleeve for pinion preload ?
The truck I bought has a howling rear of accel and I need to collect parts and maybe attempt to do it myself ??
thanks
Re: Dana 70 crush sleve ??? [Re: JohnRR] #1904122
09/01/15 03:01 PM
09/01/15 03:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No crush sleeve, shims/spacer for pinion bearing preload.
http://www2.dana.com/pdf/5312-9.pdf
Re: Dana 70 crush sleve ??? [Re: JohnRR] #1904128
09/01/15 03:08 PM
09/01/15 03:08 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Thanks John , I wasn't sure and a person I asked that has redone one said there was a crush sleeve ?
I have my 2000 shop manual at home , just need to find out if my case spreader is still at the shop that a deceased friend loaned it to, and I never got back.
Re: Dana 70 crush sleve ??? [Re: JohnRR] #1904752
09/02/15 11:02 AM
09/02/15 11:02 AM
an8sec70cuda Offline
Yep, no crush sleeve in them. I just rebuilt the Dana 70 under my '01 Ram 2500 Cummins a few months ago. Started leaking at the pinion seal and had a little whine...found worn out pinion and carrier bearings. Got the "good" bearings from NAPA and put it back together. Doing great so far.
FWIW...I don't own a case spreader. It all came apart easily. Getting the carrier back in w/ the new bearings was a little challenging, but I got it in.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 70 crush sleve ??? [Re: JohnRR] #1907665
09/06/15 10:12 PM
09/06/15 10:12 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Thanks Chip , I may try to tackle the job myself, not sure how long it's been whining?
I'm trying to take care of the front end first. I just replaced and upper control arm and swaybar links and it still makes a god awful creaking, looks like the lower bushings are shot on this side too? The cost of a replacement lower control arm is $234 compared to $43 for the upper I just changed out. eyes .
