Yep, no crush sleeve in them. I just rebuilt the Dana 70 under my '01 Ram 2500 Cummins a few months ago. Started leaking at the pinion seal and had a little whine...found worn out pinion and carrier bearings. Got the "good" bearings from NAPA and put it back together. Doing great so far.
FWIW...I don't own a case spreader. It all came apart easily. Getting the carrier back in w/ the new bearings was a little challenging, but I got it in.
