Factory Fuel pump cooler? Mopar cop car question #1903550
08/31/15 11:25 PM
08/31/15 11:25 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
So I was at the the MN State Fair and the MN State Patrol had some display cars out. Our state patrol hid a 1979 Dodge St. Regis from being sold as it was the 50th anniversary squad. I was talking with the care taker of the squad and he let me give it a good look over (the car is really unmolested). I looked under the hood and was talking to him about all the coolers these squads had. He then stated "yeah even the fuel pump had a cooler, I had to replace the pump with a normal pumps and block off the cooler lines"
I am wondering was there such a thing that mopar put on the cop car engines or did he have it confused with something emissions related?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1903554
08/31/15 11:27 PM
08/31/15 11:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Never heard of a fuel pump cooler. But who knows
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1903556
08/31/15 11:31 PM
08/31/15 11:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've seen engine oil coolers, transmission coolers, even power steering pump coolers on factory cop cars or taxis. Never seen a fuel pump cooler.
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1903570
08/31/15 11:48 PM
08/31/15 11:48 PM
minnarusta
minnarusta
Yeah that's what I thought, I had never heard of that either. I was thinking it might of been a system to help stranded motorists get gas without having to siphon from the tank. I just wanted to make sure I was correct.
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1903576
08/31/15 11:53 PM
08/31/15 11:53 PM
IN
ahy Offline
ahy  Offline
IN
A fuel cooler can help in a return style system... it cools off the return fuel which may get warm passing by the exhaust and/or engine. That way the fuel in the tank does not get hot and promote vapor lock. Never heard of one an a mechanical engine driven pump though.
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1904148
09/01/15 03:23 PM
09/01/15 03:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've seen cop cars with a fuel pump bypass (similar to a vapor separator) but never a fuel cooler.
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1904200
09/01/15 04:27 PM
09/01/15 04:27 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I think he's slightly mistaken. the oil cooler return line on every cop car I ever worked on was through a special hollow fuel pump bolt. The right hand side (front bolt). This allowed the cooler, returned oil to hit the timing chain on its way back to the pan. It's quite a brilliant design.
So that's what he's probably mentioning. I could be wrong, but there was never any production line fuel cooler. The possibility of a dealer-added on gimmick or cop garage mod is certainly there... but I doubt that. Fuel doesn't heat, and adding a cooler near the engine bay is only going to induce heat soak when idling for long periods of time or leaving the car parked. something cop cars do a lot of
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1905059
09/02/15 05:12 PM
09/02/15 05:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1905078
09/02/15 05:25 PM
09/02/15 05:25 PM
AndyF Offline
AndyF  Offline
Could be most anything, probably an emission canister or possibly the oil cooler return.
I have a buddy who was having problems with his battery not charging. The guy at NAPA told him to pull off the alternator and bring it in to be tested. This guy spent most of the day getting his truck up in the air and pulling the alternator. He took it to the NAPA store and laid it on the counter. The NAPA guy said "I thought you had a charging problem?" My buddy said "I do". Counter guy says "why did you bring me the starter?"
True story. A lot of people just don't know their way around an engine compartment.
Re: Factory Fuel pump cooler? Mopar cop car question [Re: TX9H6E4CUDA] #1905199
09/02/15 07:34 PM
09/02/15 07:34 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Having owned a bunch of Mopar Squad cars, including from that era, I think VincentVega is right. I think the caretaker was confused because of the Mopar Engine Oil Cooler line that runs thru the back bolt to fuel pump.
Facts are stubborn things.
