500 ci, 11.8 comp on 94 Pump gas, Max Wedge ported Edddy heads, Indy tunnel ram, twin Proform 950's, new MSD dist, new MSD coil, older 7AL2 (Mopar Performance), older but still look new MSD wires, new Champion 9YC plugs. Lots of fuel from carbs and did the screw driver check on every plug and seems like lots of spark (enough to zap me good a few times!!). Its always been a bear to start since I had this motor built two years ago and have had to use Quick Start spray sometimes as it floods so dam easy! But now wont even try to start. Any help or direction appreciated.
Derrick
