has fuel and spark but won't start! #1901923
08/29/15 05:12 PM
08/29/15 05:12 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
500 ci, 11.8 comp on 94 Pump gas, Max Wedge ported Edddy heads, Indy tunnel ram, twin Proform 950's, new MSD dist, new MSD coil, older 7AL2 (Mopar Performance), older but still look new MSD wires, new Champion 9YC plugs. Lots of fuel from carbs and did the screw driver check on every plug and seems like lots of spark (enough to zap me good a few times!!). Its always been a bear to start since I had this motor built two years ago and have had to use Quick Start spray sometimes as it floods so dam easy! But now wont even try to start. Any help or direction appreciated.
Derrick
Re: has fuel and spark but won't start! [Re: Hyper Henry] #1901930
08/29/15 05:25 PM
08/29/15 05:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gotta have the 3 things... spark, fuel and compression
so check compression... plugs could be soaked already..
pull a plug and check it with the wire on it.. ground
the plug
wave
Re: has fuel and spark but won't start! [Re: Hyper Henry] #1902165
08/29/15 11:55 PM
08/29/15 11:55 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Sounds like the dizzy is 180 out.
Re: has fuel and spark but won't start! [Re: Mopar_Rich] #1902255
08/30/15 03:50 AM
08/30/15 03:50 AM
timing and or MSD issue. recent issue? any changes preceding it acting up?
Re: has fuel and spark but won't start! [Re: Hyper Henry] #1902338
08/30/15 11:14 AM
08/30/15 11:14 AM
Ontario, Canada
Ontario, Canada
Thanks guys I got it going. Combination of a couple things, coil wire had some cracks in it and was wet after washing the car and had a lot of resistance when I checked it with meter and distributor cap and reluctor had a lot of corrosion/rust.
How the heck do you keep these MSD distributor parts from rusting. Its only a couple months old!
Re: has fuel and spark but won't start! [Re: Hyper Henry] #1902368
08/30/15 12:06 PM
08/30/15 12:06 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
WD-40
I used to carry a can in my 4x4 so if I got the distributor wet I could restart the truck.
Just pull the cap and spray everything good.
Hope this helps,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
