Page 10 of 48 1 2 8 9 10 11 12 47 48
Re: Modern Bullitt build [Re: Keepat] #1901801
08/29/15 12:42 PM
08/29/15 12:42 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Of all of the cool cars I've seen on Moparts since I started coming here in 1999, this is my favorite, and by a wide margin. Thank you for taking the time to document this incredible build. Your talent is off the charts.
Earning every penny of that moderator paycheck.
DBAP
Re: Modern Bullitt build [Re: not_a_charger] #1901888
08/29/15 04:00 PM
08/29/15 04:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you! This car has been fun to build and I have enjoyed documenting and Posting the progress. Thank you for your comments.
Pat
Re: Modern Bullitt build [Re: Keepat] #1901957
08/29/15 06:15 PM
08/29/15 06:15 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Oh yes! It's a good thing that you have documented every aspect of your amazing build, because then you will know how to build another Charger when I take possession of this one! Ha-ha-ha! I am so envious of your awesome car and incredible skills! This is definitely the best build threat ever! There so much more great things to say, but I don't want to keep you from all the fun you are having, while providing us lucky members some wonderful entertainment! Go Pat go!
Re: Modern Bullitt build [Re: Hooligan] #1902555
08/30/15 06:01 PM
08/30/15 06:01 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank You sir!
Today I replaced the right side radiator core support so I can use the larger radiator. The new part fit nice and I spot-welded it in place. I hope to test fit the new radiator next week.
Pat
Re: Modern Bullitt build [Re: Keepat] #1906551
09/04/15 10:16 PM
09/04/15 10:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
All the AC lines are finished and the drier & condenser have been test fit. So far I’m very happy with the Vintage Air Mopar B Body system. I’m getting closer to putting the car on the rotisserie.
Pat
Re: Modern Bullitt build [Re: Keepat] #1907528
09/06/15 04:47 PM
09/06/15 04:47 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I'm envious of your skills sir! bow
One question about the AC line routing, are you going to make some kind of cover/shield to protect them from road debris? My luck, a rock, or even worse, a blow out would take out all that hard work..... whiney
popcorn
John
Re: Modern Bullitt build [Re: Keepat] #1907534
09/06/15 05:22 PM
09/06/15 05:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I had one bad spot in the right side cowl vent that needed a small repair, but fortunately it was accessible. The right side cowl vent is not used with new Vintage Air system; there is a plate that will cover it. Now I can water test it with a rust converter and spray it down with sealer. If anyone has a proven method for access, cleaning, and coating the inside of the cowl please let me know.
Pat
Re: Modern Bullitt build [Re: SattyNoCar] #1907545
09/06/15 05:40 PM
09/06/15 05:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
popcorn
The S/S lines are over kill for this job as they are rated for over 2500 PSI working pressure. I think they could take the shrapnel as good as the fender has for over 45 years. The AC lines will get a 3/16 neoprene insulator that will also help protect them as the undercoating protected the inside of the fender.
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #1908963
09/09/15 12:02 AM
09/09/15 12:02 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I fitted and welded in the left side US Car Tool inner fender brace. It needed a little massaging but fit really nice. Right side is next!
Pat
Re: Modern Bullitt build [Re: Keepat] #1910009
09/10/15 04:09 PM
09/10/15 04:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received my Griffin radiator yesterday so with the motor still in the car I test fitted it. I’m going to weld a 90 degree pipe on the thermostat housing so it will have a short top hose.
Pat
Re: Modern Bullitt build [Re: Keepat] #1911551
09/13/15 11:06 AM
09/13/15 11:06 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
In threads over on the a-body forum I have seen people remove windshield and drill out all the outer cowl spot welds and remove top outer shell of cowl. Then you will have full access. Other than that you cant get in there.
Re: Modern Bullitt build [Re: Keepat] #1913927
09/16/15 06:54 PM
09/16/15 06:54 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Disassembled the brake pedal assembly and added the clutch pedal. Next I will fit the assembly to the Hydroboost and hydraulic clutch.
Pat
Re: Modern Bullitt build [Re: Keepat] #1915583
09/19/15 12:21 PM
09/19/15 12:21 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I test fitted the pedal assembly and had to weld over the original brake booster hole and cut a new hole in the firewall reinforcement mount. Also test fit the hydroboost and clutch master cylinder. I need to make the hydro boost and brake lines next.
Pat
Re: Modern Bullitt build [Re: Keepat] #1918742
09/24/15 01:29 PM
09/24/15 01:29 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Mounted the clutch reservoir and used ¼ S/S tubing for the line.
Pat
Re: Modern Bullitt build [Re: Keepat] #1919294
09/25/15 06:26 AM
09/25/15 06:26 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Very awsome project! Here is my cowl removed to repair old holes from racing in the top center of inner cowl. I hated to do it but only way to get full access. On a plus now can clen up vent holes correctly.
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Modern Bullitt build [Re: Keepat] #1919315
09/25/15 09:38 AM
09/25/15 09:38 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks for the great picture! Mine looks a lot like yours inside so I'm going to try to chemically treated without removing the cowl.
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #1920847
09/27/15 09:30 PM
09/27/15 09:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I bent the Hydroboost and power steering lines to fit in the left side inter fender well. I used 3/8” stainless steel .035 wall tubing. All this test fitting, wiring, and line bending just to pull it all out before the bodywork starts is a lot of work!! I’m sure I will enjoy having all this work behind me after the car is painted. Wait that sound like I’m looking forward to the bodywork ;-(
Pat
Re: Modern Bullitt build [Re: Keepat] #1924466
10/02/15 09:36 PM
10/02/15 09:36 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Went to Carlisle today and pickup my original front and back seats that I had dropped off with Legendary this past spring. They recover the front & back seat and I went with their Rallye front seat upgrade. I’m very happy with the look, shape, and fit!
Pat
Re: Modern Bullitt build [Re: Keepat] #1924719
10/03/15 03:07 AM
10/03/15 03:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Did you beef the lower rad support ala the old XV brace?
I want my fair share
Re: Modern Bullitt build [Re: SomeCarGuy] #1924769
10/03/15 09:41 AM
10/03/15 09:41 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
It is a US Car Tool lower rad support that I special ordered without the holes in it so it looks original. Fit and worked great!
Thank you!
Pat
