How far have you pushed a 904? #1901324
08/28/15 07:54 PM
08/28/15 07:54 PM
kentucky
roadrunner7020 Offline OP
kentucky
I'm slowly putting together a duster street strip car, I may be able to get a good deal on a built 904 with a transbrake and good clutches etc. How far have you all pushed these units I know my uncle had been high 5s but that was in a chassis car and much lighter then the estimated 3300lbs my car will likely go. Just curious what you've pushed them to this will he a small block turbo car with a low numerical gear (3.23 or 3.55) so maybe it will be easier in drive line parts. Thanks in advance.
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901342
08/28/15 08:26 PM
08/28/15 08:26 PM
CT
turbocolt2.4L Offline
CT
So far mine is holding up very good basic trans good frictions and kolene steels A&A brake lba clean neutral oem input and output shafts..2700 pbs turbo 4cyl 26x8.5 slick 4.30 rear gear 731 rwhp put about 150 hits on it a year ..
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901345
08/28/15 08:28 PM
08/28/15 08:28 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
9.8@ 139 in a 3600lb car. Shooting for bottom 9s
Re: How far have you pushed a 904? [Re: 1980volare] #1901348
08/28/15 08:32 PM
08/28/15 08:32 PM
kentucky
kentucky
Thanks for the info guys I'm shooting to land in the range you all are at so if its holding there I'm not really scared to try it at all. Either one of you still running a 8.75?
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901391
08/28/15 09:33 PM
08/28/15 09:33 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Yup. 35 spline, factory 3.23 gear.
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901557
08/29/15 12:20 AM
08/29/15 12:20 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Basically stock 904 with good clutches & bands, RMVB, footbrake, 6000 stall, slicks, 3000 lbs, 600HP was the limit if I didn't do something stupid. Like leaving in 2nd; that would hurt clutches.
At 640HP needed better parts in it, but this one's a CRT and holding up well. 368" SB, just a single carb.
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901589
08/29/15 01:02 AM
08/29/15 01:02 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
After 4 years still running my 904 with a spring pack, 5 discs clutch,
rev manual valve body 5000rpm stall, steel planetary from an A-998
All in a 3100 lbs 67 Barracuda
606hp Indy Headed 408
best 60ft 1.30 sec , 6.40 sec 1/8 mile
Still running as new
Dan
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901613
08/29/15 01:36 AM
08/29/15 01:36 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I'm still pushing mine 5.66 @ 120
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901640
08/29/15 02:18 AM
08/29/15 02:18 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Wowww !!!
How much do you weight ?
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901700
08/29/15 08:59 AM
08/29/15 08:59 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
picts of broken parts please David :P
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901767
08/29/15 11:54 AM
08/29/15 11:54 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Race ready 2850 #. Yeah its broken some parts. Input and output shafts, sprag, output shaft bushing. I now have billet shafts and use good pieces there. I get ok life on clutches and bands. I'll soon start on a 2.25 1.45 geared 904. I should most likely build a glide but I have quite a few 904 parts. I finally changed the 8 3/4 to a dana.
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901785
08/29/15 12:19 PM
08/29/15 12:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you know if you go glide I'll give you pennies on the dollar for those 904 pieces! I should go glide too, but keep fumbling along with 727 stuff. I do have a decent 904, but I don't think the converter I have would be up to par for the W8 deal, and I would need yokes and a new driveshaft. The 904 was mated to our high 10 iron head 360.
Re: How far have you pushed a 904? [Re: roadrunner7020] #1901831
08/29/15 01:47 PM
08/29/15 01:47 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Ha Ha I'll keep that in mind. I figure I'll spend $3500-$4000 to change to a glide. That's with a Reid case and bell adapter
Re: How far have you pushed a 904? [Re: DavidDean] #1901841
08/29/15 02:13 PM
08/29/15 02:13 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
A friend is doing that right now. I asked him if he hit the $10,000 mark yet and said he recently added it up to only $8800! That's before finding out the new converter won't work with the TCI adapter flexplate, and adding in my labor fees. I took a Bryant hemi crank in partial payment for my efforts. Driveshaft still needed too.
Re: How far have you pushed a 904? [Re: @#$%&*!] #1902004
08/29/15 07:18 PM
08/29/15 07:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Been 9.87@133.with mine and numerous 9.90's and low 10. passes with mine after I finally figured out how to build one.
Re: How far have you pushed a 904? [Re: DavidDean] #1902056
08/29/15 08:59 PM
08/29/15 08:59 PM
SoCal
Brian Hafliger Offline
SoCal
How's the new engine build going??
Brian Hafliger
Re: How far have you pushed a 904? [Re: roadrunner7020] #1902172
08/30/15 12:14 AM
08/30/15 12:14 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
SLOW !!! Thanks for asking. I've been doing nothing but work. Now that school has started I can make some progress. I've been working through crank throw- oil pump clearance issues but maybe I have it solved. I might be ready for assembly mid October. Maybe dyno after that... I hope!
