Re: How far have you pushed a 904?
[Re: roadrunner7020]
#1901557
08/29/15 12:20 AM
08/29/15 12:20 AM
Posts: 20,773 A collage of whims
topside
A collage of whims
Basically stock 904 with good clutches & bands, RMVB, footbrake, 6000 stall, slicks, 3000 lbs, 600HP was the limit if I didn't do something stupid. Like leaving in 2nd; that would hurt clutches. At 640HP needed better parts in it, but this one's a CRT and holding up well. 368" SB, just a single carb.
#1901589
08/29/15 01:02 AM
08/29/15 01:02 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
After 4 years still running my 904 with a spring pack, 5 discs clutch, rev manual valve body 5000rpm stall, steel planetary from an A-998
All in a 3100 lbs 67 Barracuda 606hp Indy Headed 408 best 60ft 1.30 sec , 6.40 sec 1/8 mile Still running as new
Dan
[Re: DavidDean]
#1901841
08/29/15 02:13 PM
08/29/15 02:13 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Ha Ha I'll keep that in mind. I figure I'll spend $3500-$4000 to change to a glide. That's with a Reid case and bell adapter A friend is doing that right now. I asked him if he hit the $10,000 mark yet and said he recently added it up to only $8800! That's before finding out the new converter won't work with the TCI adapter flexplate, and adding in my labor fees. I took a Bryant hemi crank in partial payment for my efforts. Driveshaft still needed too.
[Re: @#$%&*!]
#1902004
08/29/15 07:18 PM
08/29/15 07:18 PM
dartman366
Mt. Vernon, Ohio
Been 9.87@133.with mine and numerous 9.90's and low 10. passes with mine after I finally figured out how to build one.
[Re: DavidDean]
#1902056
08/29/15 08:59 PM
08/29/15 08:59 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Ha Ha I'll keep that in mind. I figure I'll spend $3500-$4000 to change to a glide. That's with a Reid case and bell adapter How's the new engine build going??
Brian Hafliger
