070 fan clutch ?
#1898496
08/24/15 05:56 PM
08/24/15 05:56 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I have what I believe is an 2806 070 fan clutch. Hoping someone can provide the dimension from the end of shaft (pulley mounting surface) to the fan mounting surface (4 bolts that attach fan) so I can measure mine to confirm. Also any other features that will help me confirm this is indeed an 070 clutch would be appreciated. Thanks in advance.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 070 fan clutch ?
[Re: 70gtx440dana]
#1898513
08/24/15 06:39 PM
08/24/15 06:39 PM
Posts: 4,114 MD
floyd
MD
[Re: floyd]
#1898527
08/24/15 06:56 PM
08/24/15 06:56 PM
70gtx440dana
Lansing, MI
Great link.....very informative. Looks like an 070 clutch should have a 1 1 1/4" shaft length. Mine is 1 1/8" which is not discussed in this thread. It came with a 116 fan unit attached. I will have to do a bit more research to figure out what I have.
[Re: Morty426]
#1900893
08/28/15 03:57 AM
08/28/15 03:57 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
A picture always helps.
The 112 is shorter but the same in appearance then the 070.
Morty, you are wrong, the 112 is 1/4 inch longer than the 070
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1900907
08/28/15 06:42 AM
08/28/15 06:42 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Morty, you are wrong, the 112 is 1/4 inch longer than the 070 Yep you're right. I was thinking about it backwards. The 112 is closer to the radiator meaning it's longer.
[Re: 70gtx440dana]
#1900969
08/28/15 11:01 AM
08/28/15 11:01 AM
70gtx440dana
Lansing, MI
Anybody have an idea on what application is 1/8" shorter than an 070? I have convinced myself to use this one even if not 100% correct as it is in great shape.
[Re: 70gtx440dana]
#1901072
08/28/15 01:25 PM
08/28/15 01:25 PM
70gtx440dana
Lansing, MI
Bill,
Thanks for the heads up....I will make sure I am not to close to anything on the front of engine. If so, I will have to come up with another plan. It is my hope the 1/8" won't be a problem. I have my fingers crossed.
