070 fan clutch ? #1898496
08/24/15 05:56 PM
08/24/15 05:56 PM
Lansing, MI
70gtx440dana Online content OP
70gtx440dana  Online Content OP
Lansing, MI
I have what I believe is an 2806 070 fan clutch. Hoping someone can provide the dimension from the end of shaft (pulley mounting surface) to the fan mounting surface (4 bolts that attach fan) so I can measure mine to confirm. Also any other features that will help me confirm this is indeed an 070 clutch would be appreciated. Thanks in advance.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 070 fan clutch ? [Re: 70gtx440dana] #1898513
08/24/15 06:39 PM
08/24/15 06:39 PM
MD
floyd Offline
floyd  Offline
MD
Here's an old post with some pics and measurements:
https://board.moparts.org/ubbthreads/ubbt...dimensions.html
Re: 070 fan clutch ? [Re: floyd] #1898527
08/24/15 06:56 PM
08/24/15 06:56 PM
Lansing, MI
Lansing, MI
Great link.....very informative. Looks like an 070 clutch should have a 1 1 1/4" shaft length. Mine is 1 1/8" which is not discussed in this thread. It came with a 116 fan unit attached. I will have to do a bit more research to figure out what I have.
Re: 070 fan clutch ? [Re: 70gtx440dana] #1900201
08/27/15 03:35 AM
08/27/15 03:35 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
A picture always helps.
The 112 is shorter but the same in appearance then the 070.
Re: 070 fan clutch ? [Re: Morty426] #1900893
08/28/15 03:57 AM
08/28/15 03:57 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Morty, you are wrong, the 112 is 1/4 inch longer than the 070
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 070 fan clutch ? [Re: AZ_A12_BEE] #1900907
08/28/15 06:42 AM
08/28/15 06:42 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yep you're right. I was thinking about it backwards. The 112 is closer to the radiator meaning it's longer.
Re: 070 fan clutch ? [Re: 70gtx440dana] #1900969
08/28/15 11:01 AM
08/28/15 11:01 AM
Lansing, MI
Lansing, MI
Anybody have an idea on what application is 1/8" shorter than an 070? I have convinced myself to use this one even if not 100% correct as it is in great shape.
Re: 070 fan clutch ? [Re: 70gtx440dana] #1900973
08/28/15 11:12 AM
08/28/15 11:12 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
dont know the application for one that is shorter, but the guys that rebuild them can sometimes set them to the correct height.
Re: 070 fan clutch ? [Re: Morty426] #1901026
08/28/15 12:27 PM
08/28/15 12:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Joe,I would imagine anything much shorter in height would create an issue by putting the fan blades closer to what is behind it rather than being close to the radiator.I had to mill a 1" spacer to get clearance on my wagon with a 7 blade fixed fan,no room for any clutch fan,you can see how close it is.
Re: 070 fan clutch ? [Re: 70gtx440dana] #1901072
08/28/15 01:25 PM
08/28/15 01:25 PM
Lansing, MI
Lansing, MI
Bill,
Thanks for the heads up....I will make sure I am not to close to anything on the front of engine. If so, I will have to come up with another plan. It is my hope the 1/8" won't be a problem. I have my fingers crossed.
