INDY 572 - 13 Head Porting / Flow question
#190067
01/10/09 10:23 PM
01/10/09 10:23 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I notice INDY lists two different specs on the 572-13 heads... one is the CNC-365 and one is CNC-385 The 365 is listed for a C.I.D of 528"-572" The 385 is listed for a C.I.D of 572"-605" I know the CC vol,,and Flow are different for each head... Question: How do you decide which to choose IF you were doing a 572 Wedge motor ? Does it depend more on "what" your using the motor for ? (in general),,what other things do you have to consider when choosing.... Just doing some research Can you guys give me some idea on what type of valve train components that are used/recomended for the 572 INDY head as well,,,, Jesel ?,,, Thanks,,,, Doug
Re: INDY 572 - 13 Head Porting / Flow question
[Re: 69CHARGERMD]
#190068
01/10/09 11:29 PM
01/10/09 11:29 PM
jesel is used
[Re: smokinwoody]
#190070
01/11/09 02:36 PM
01/11/09 02:36 PM
69CHARGERMD
KENTUCKY
Thanks Poppj,,,i thought it was the Jesel stuff.... (i thought you guys were running a 572,,or Casey was ?),,if so,,would be curious to hear the setup,,(block,heads,etc that were used) Smokenwoody,,just looking for now,,,not ready to purchase anything,,,building a "parts" list so i know what to do. Those heads sure look nice,,,,do you have numbers on what Hensley did with them ?,,,port/flow,,etc,,are you selling them with the Jesel valvetrain stuff,,,etc ? thanks,,, Can anyone comment on the difference in flow numbers,,and the two different port options,,,,and which would be best for a 572 motor,,,,
[Re: Bob_Coomer]
#190072
01/11/09 03:41 PM
01/11/09 03:41 PM
69CHARGERMD
KENTUCKY
RT,,, Thanks,,,i know the B1 stuff is nice,,, I am going for a 572 NSS motor,,, i know alot of those guys are running the INDY intake,,dual carbs,,etc,,to "comply" with the NSS "rules".. your sig says HEMI coming soon ?,,
[Re: 69CHARGERMD]
#190074
01/11/09 05:36 PM
01/11/09 05:36 PM
Yea we are running a 588 (poppaJ's car I just drive it)
indy aluminum block 572-13 385's, some work done to them jesel 1.7 rockers callies crank spray bar oiling on them as well oliver rods ross pistons...
made 1080hp on the dyno (tunnel ram and 2 1050's)
makes a bit less with them crossram...
Casey
but we will have a new set up to try here shortly on it.
Good luck with the build!!
#190075
01/11/09 06:21 PM
01/11/09 06:21 PM
69CHARGERMD
KENTUCKY
Casey,,,NICE,,, Do you recall what kind of numbers it ran with the crossram,,,, Do you recall who did the carb work ,,,, I am going for something very similar,,,,INDY alum block, 572 heads, etc,,,havent pulled the trigger,,,still "looking" into things,,,
[Re: 69CHARGERMD]
#190076
01/11/09 06:30 PM
01/11/09 06:30 PM
Damon Kuhn from Diamondback racing engines did the carbs. And we never got any good numbers with the crossram set up... it went 9.70's at 140, but just had a lot od problems with the tranny... should be faster just didnt get out much last year. It was in the 7's in a chassis car with the tunnel ram of course.... SUPERSTOCKRACER has been 9.20's with more or less the same set up. Casey
#190077
01/12/09 09:00 AM
01/12/09 09:00 AM
Posts: 2,933 A shed in England
Tig
A shed in England
Wow impressive! Sorry to thread hijack but what did the heads flow? can you remember the cam specs? I need a tunnel ram
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 69CHARGERMD]
#190079
01/12/09 11:46 PM
01/12/09 11:46 PM
fast68plymouth
So. Burlington, Vt.
depending on the race weight, and the final engine/chassis combo, and desired performance level.....i'd also consider the 440-1 CNC345's.
[Re: 69CHARGERMD]
#190080
01/12/09 11:54 PM
01/12/09 11:54 PM
id personally forget the 572 and go to a 588 4.625 stroke, in a heavy car you'll need all the power you can get. poppaj and my engine combo is very similar.i use T & D roller rockers, dont skimp on any part if you want to go fast. im going 9.20-9.22 all motor and footbraking on 10.5 tire for NSS. now and building a B1 motor for the new combo to go in the mid to upper 8's this year.
