RPM rust preventer #1900476
08/27/15 04:04 PM
08/27/15 04:04 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
is this still the product to use to keep bare metal looking like bare metal and preventing rust?
Re: RPM rust preventer [Re: mikemee1331] #1900493
08/27/15 04:29 PM
08/27/15 04:29 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Stuff I used it on still looks great!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: RPM rust preventer [Re: JMCFAN] #1900637
08/27/15 09:10 PM
08/27/15 09:10 PM
N. Ca.
floorit426 Offline
floorit426  Offline
N. Ca.
Can it be used on exhaust systems?
Re: RPM rust preventer [Re: mikemee1331] #1900723
08/27/15 10:57 PM
08/27/15 10:57 PM
jersey
Spaceman Spiff Offline
jersey
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: RPM rust preventer [Re: mikemee1331] #1901404
08/28/15 09:50 PM
08/28/15 09:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
it may work well on a low mileage vehicle kept from the weather, but i used it on some nuts and bolts on my truck and they practically rusted like nothing was on them
Re: RPM rust preventer [Re: mikemee1331] #1901516
08/28/15 11:42 PM
08/28/15 11:42 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'm very happy with how it works but it takes more than advertised in my experience.
Re: RPM rust preventer [Re: Morty426] #1901698
08/29/15 08:50 AM
08/29/15 08:50 AM
bethlehem pa
bethlehem pa
more initial product or coats?
Re: RPM rust preventer [Re: mikemee1331] #1901740
08/29/15 11:02 AM
08/29/15 11:02 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe more coats would have worked better for me. It seems to be some type of a wax(?) that melts with the heat. I`m pretty sure I followed the directions correctly.
Re: RPM rust preventer [Re: mikemee1331] #1901744
08/29/15 11:12 AM
08/29/15 11:12 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Supposedly one is good enough for one car. I've used two for my restoration. I'm sure some times I was putting it on too thick, but I really think enough for one car is a little bit of a stretch.
Love the product by the way.
Re: RPM rust preventer [Re: Morty426] #1902155
08/29/15 11:35 PM
08/29/15 11:35 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I just read through the test results. Seems like pretty sturdy and resilient stuff.
anyone have any real world experience of the product NOT working as advertised?
And too bad you have to heat the part to brush on the product. RPM needs to create a similar product that comes in a spray solution so you can spray it into nooks and crannies of car body cavities where you don't get paint applied.
I need to do something to my 06 Ram 2500 to prevent the sheet metal from rusting away, and I need to do it before any rust even starts!
**Photobucket sucks**
Re: RPM rust preventer [Re: mikemee1331] #1902304
08/30/15 09:01 AM
08/30/15 09:01 AM
bethlehem pa
bethlehem pa
i asked cause i have to replace my master cylinder and they are SO nice when you get them but in a couple of year exposed to humidity and dripped brake fluid, well you all know!
Re: RPM rust preventer [Re: mikemee1331] #1902348
08/30/15 11:27 AM
08/30/15 11:27 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Depending on the year the MC has a unique plating that is not very rust proof. Check with MasterShake340 as to what it is since I cannot remember off the top of my head. Had some plated that I did not protect with RPM and they rusted up pretty quick. The plating shop had mercy on me when I re did them. Put RPM on the and they have looked great for 4 years now.
Re: RPM rust preventer [Re: Morty426] #1902441
08/30/15 02:24 PM
08/30/15 02:24 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
This stuff works great but when using a heat gun it melts every brush I've used ! Maybe I can heat the part with the Heatgun and then spread the rpm with a warm hairdryer.
Still looking for LM29H1B415501, '71 Demon 340
Re: RPM rust preventer [Re: mikemee1331] #1902453
08/30/15 02:58 PM
08/30/15 02:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Morty, you are "plating" MC's? Lids maybe? shruggy
Re: RPM rust preventer [Re: PAULS_340] #1902492
08/30/15 03:58 PM
08/30/15 03:58 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I heat the item that I am using it on by first warming in the sun. I then warm further with a heat gun. Only then do I place my brush into the RPM container loading it with the product. Then just like applying paint spread it about. Not my brush, nor any animals were hurt doing in this way.
Just did a new master cylinder last month,,,so far looks fine. Will say that using the product you might experience a slight dulling of the native metallic sheen of the original cast iron. Has been my experience, but overall a better outcome than anything else I've used.
Re: RPM rust preventer [Re: Sxrxrnr] #1902503
08/30/15 04:31 PM
08/30/15 04:31 PM
bethlehem pa
bethlehem pa
do you have to do it a side at a time or can you heat sides and keep going? is it affected by by 'over-lap' meaning the dullness you mentioned look duller when you over-lap?
Re: RPM rust preventer [Re: ScottSmith_Harms] #1902945
08/31/15 02:37 AM
08/31/15 02:37 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
yep plated the MC and the lid. Looks great.
Re: RPM rust preventer [Re: mikemee1331] #1903028
08/31/15 10:40 AM
08/31/15 10:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I smell ribs again drool
Re: RPM rust preventer [Re: mikemee1331] #1903200
08/31/15 03:37 PM
08/31/15 03:37 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Leave it sun, then heat up the whole item additionally with heat gun, then rather quickly paint the whole item. Does not have to be too hot,,,would be good if RPM would suggest range of appropriate temperatures that one could test with one of those laser heat temp guns.
I would not overheat a MC as could be possible to damage seals I suppose. Some heat guns can generate a very high temp.
If you install MC and other underwood items, likely a drive of vehicle would heat up to sufficient temperature to make RPM happy.
Final finish will always be a bit duller than natural glint,,,,somewhat as a clear coat,,,not bad just a bit different.
Re: RPM rust preventer [Re: Sxrxrnr] #1903373
08/31/15 07:30 PM
08/31/15 07:30 PM
bethlehem pa
bethlehem pa
thanks for the tips! i'll most likely swipe the wife's hairdryer while she is at work whistling and try that first.
