1974 340 Boat engine ? #1899528
08/26/15 01:22 AM
08/26/15 01:22 AM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
BOAT = Break Out Another Thousand. So I got myself caught up in the restoration of a '74 Conqueror SuperBee III. Long story short, the original 340 is shot, looks like from detonation. Having a hard time finding anyone who knows anything about this engine. I'm tempted to just drop a common 318 back in but know I'll regret not keeping the 340 in it. I need some piston recommendations for this 340. I don't want high compression, hopefully something around 9:1. I've never owned a small block. Are all the heads the same? Thanks for any info. Mike
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1899597
08/26/15 05:06 AM
08/26/15 05:06 AM
In 1972 Mopar lowered the compression ratio on all car 340 motors to 8.5 to 1, that is in blueprint specification. Mopar never blueprinted any production motors so the average car motor had less than that spec. work My message is to go ahead and buy good quality replacement piston for the 1972,73 car motors and check the deck hieghts, combustion chamber volumes and see what true compression ratio you get scope thumbs use the head gasket thickness to help achieve the compression ratio you want thumbs IHTHs
Re: 1974 340 Boat engine ? [Re: Cab_Burge] #1899598
08/26/15 05:16 AM
08/26/15 05:16 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Agree with Cab
As to your other question, No, all the (SB) heads are Not the same. (Click on Link below for Hot Rod Mag article on SB Heads)
http://www.hotrod.com/how-to/engine/mopp-0607-mopar-cylinder-head/
I am fairly new to Mopar SB's too. Just bought my first one, an LA 360, in the '74 Dodge Power Wagon I bought last November.
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1899608
08/26/15 06:48 AM
08/26/15 06:48 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If the block doesn't check out to be good, do a stroker 318, not so common.
By late 72 340's had a very sturdy cast crank, forged went away. 340's, and 360's, have bigger port/valve heads than a 318.
But, since you said "restoration", do the 340.
Re: 1974 340 Boat engine ? [Re: Dean_Kuzluzski] #1899665
08/26/15 11:42 AM
08/26/15 11:42 AM
If you're wanting to be out on the water for what is left of the summer months what about dropping in the 318 to get you up & running then we can help you get the 340 rebuilt/setup for high rpm longevity. (simply) Sounds like the PO didn't use enough octane.
Re: 1974 340 Boat engine ? [Re: RapidRobert] #1899666
08/26/15 11:44 AM
08/26/15 11:44 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
iagree Boats are under constant load, like pulling a trailer uphill in a vehicle all the time...
Re: 1974 340 Boat engine ? [Re: minivan] #1899668
08/26/15 11:49 AM
08/26/15 11:49 AM
that jogged my memory & once I worked on an inboard 318 speedboat & it was reverse rotation! took awhile to figure that one out (firing order)
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1899853
08/26/15 05:05 PM
08/26/15 05:05 PM
Phoenix, AZ
Phoenix, AZ
This one seems normal rotation. The firing order runs clockwise. The numbers on the side of the block is 2780930-340 and there's a larger # 7 cast near that. The head #'s seem to be 2843 and I think 678 but might be 578 or 576 - 21
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1899873
08/26/15 05:45 PM
08/26/15 05:45 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have always thought why didn't boat manufacturers reverse the rotation on the props made to accomodate standard rotation engines??
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1899923
08/26/15 07:39 PM
08/26/15 07:39 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Twin engine shaft drive boats usually had one regular rotation engine and one reverse rotation engine. At least that is how I remember them.
Re: 1974 340 Boat engine ? [Re: minivan] #1900018
08/26/15 10:29 PM
08/26/15 10:29 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The prop on many single inboard engine boats turns clockwise(CW/reverse/right hand rotation) to help trim the boat.
When a boat is operated by only one person sitting on the starboard (right) side, the operators weight creates a list to the right. If the prop turns CCW (std automotive rotation), the torque it produces will also create a list to the right. So by turning the prop CW, it's torque now creates a list to the left, which will help counter the list on the right caused by the drivers weight. Hopefully the two are near equal so the boat will trim up level.
When more than one person is in the boat, they can shift their sitting positions to help with trim, one person doesn't have that possibility.
A bit of trivia, Chrysler Marine V8s didn't use the AVS's, almost all used a AFB's modified for marine use.
Re: 1974 340 Boat engine ? [Re: mopars4ever] #1900019
08/26/15 10:30 PM
08/26/15 10:30 PM
IN
ahy Offline
ahy  Offline
IN
If you do change to a newer style engine, I'd suggest 360 to better match torque and power of the previous engine. With the same prop and gearing, it should run a little easier vs the 340. A 318 would have to run hard unless you reduce prop pitch.
Excess load from too much pitch can contribute to detonation. With full throttle the engine should max out around 4300-4500 RPM. Less than that means too much pitch, more means not enough.
Re: 1974 340 Boat engine ? [Re: ahy] #1900050
08/26/15 11:07 PM
08/26/15 11:07 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Most Chrysler Marine motors have special oil pans and timing cover, so if he went with a 360 he'd have to locate them.
If it were me and if I'm buying new pistons, might as well get new rods and a 4" crank to go with them and throw them in a 318 block. What's a plus .030 318 with a 4" arm? 390"? That should do it.
Yes, boat motors have a load on then all the time they are cruising. If it has the original dist, notice there is NO vac adv pod. It's easy for a prior owner to jack up the timing to auto specs and causing detonation. Check the owners or shop manual for total timing, it will far less than automotive, 10* less, maybe more.
First thing I'd do is verify that the 340 is a RH/CCW/standard rotation. Internal parts will be the same as automotive.
If it's LH/CW/reverse rotation, careful with the cam and dist drive gear. There are new ones available for the SB and pricey but at least you can get them, only choices for the BB is used.
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1900452
08/27/15 03:36 PM
08/27/15 03:36 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
TY for the prop rotation comments above...
Re: 1974 340 Boat engine ? [Re: B5 Bee] #1901000
08/28/15 11:45 AM
08/28/15 11:45 AM
Phoenix, AZ
Phoenix, AZ
Just to make sure... when checking for clockwise or ccw are we looking at the front of the engine or referenced from the rear? Thanks
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1901110
08/28/15 02:25 PM
08/28/15 02:25 PM
dogdays Offline
dogdays  Offline
Looking at the engine from the front, like where the crank was on antique cars.
R.
Re: 1974 340 Boat engine ? [Re: minivan] #1901147
08/28/15 02:54 PM
08/28/15 02:54 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Can't do it, one engine would be pushing forward the other would be in reverse.
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1901167
08/28/15 03:47 PM
08/28/15 03:47 PM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline
Any pictures of that boat you are restoring?
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1901184
08/28/15 04:28 PM
08/28/15 04:28 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
If the boat was raw water cooled, there's a good chance that the block is thin from years of rusting in the water jackets.
Find a good replacement block that had antifreeze in it.
Also, you really need to find a shop that builds marine stuff. There are LOTS of subtle differences that will bite you. (Carb setup, piston to wall clearance, valve guide clearance, oiling, cam selection etc........) don't think you can just drop in an automotive engine and be good to go.
unions....the folks who brought you the weekend!
Re: 1974 340 Boat engine ? [Re: MCTPhoenix] #1901252
08/28/15 06:48 PM
08/28/15 06:48 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
First, let me correct my post.
"First thing I'd do is verify that the 340 is a LH/CCW/standard rotation.""
From the rear or like you're in the drivers seat.
Standard rotation is CCW or Left Hand.
Reverse is CW or Right Hand.
