Console mount cassette player 71 cuda #1899744
08/26/15 02:07 PM
08/26/15 02:07 PM
kansas
johngeery Offline OP
kansas
I have a cassette player that has the floor mount bracket, and I need to switch it with the console mount bracket (the two metal pieces) Does anyone reproduce these?
I thought I saw them on here long ago for about $33 each, but now they are proving to be difficult to track down.
This is a 71 cuda automatic console car.
I may need that little U-shaped base thing too
Re: Console mount cassette player 71 cuda [Re: johngeery] #1899980
08/26/15 09:18 PM
08/26/15 09:18 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
The part#s you would be looking for are.
3501123 console bracket upper.
3501085 " " lower under console.
3501124 shroud lower with console.
maybe the numbers can @ least help U track down the needed parts
P.S. I may be interested in the floor mount brackets.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1900001
08/26/15 10:01 PM
08/26/15 10:01 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I made some prototypes a few years ago, I might have some in stock, I'll post pics of what I have.
Re: Console mount cassette player 71 cuda [Re: ScottSmith_Harms] #1900010
08/26/15 10:18 PM
08/26/15 10:18 PM
kansas
kansas
Thanks Scott ! I would be very interested.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1901845
08/29/15 02:24 PM
08/29/15 02:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Which one of these parts do you need? There is another bracket not shown, possibly the one you need?
Re: Console mount cassette player 71 cuda [Re: ScottSmith_Harms] #1901921
08/29/15 05:09 PM
08/29/15 05:09 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The two smaller pieces are correct for a console mounted deck. They should be plated zinc dichromate.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1901925
08/29/15 05:18 PM
08/29/15 05:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hold your critique for now Dwight, they are just unfinished prototypes up
Re: Console mount cassette player 71 cuda [Re: ScottSmith_Harms] #1902339
08/30/15 11:16 AM
08/30/15 11:16 AM
m46rat Offline
m46rat  Offline
I realize that. I'm just letting you know in case you didn't.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1902490
08/30/15 03:53 PM
08/30/15 03:53 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I'm quite sure member here, Bill Alphin reproduced those, plated in correct zinc dichromate.
He had a few boxes full of them at Chryslers at Carlisle 2 years ago just freshly done and very reasonably priced.
They looked spot on.
This bottom plastic piece with lip 3501124 will be, and is, the toughest cassette player part to find
Re: Console mount cassette player 71 cuda [Re: johngeery] #1902537
08/30/15 05:27 PM
08/30/15 05:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Which reminds me of why I stopped at the prototypes, professional courtesy, no need for two vendors selling the same small demand part that's already available as an accurate reproduction. up
Re: Console mount cassette player 71 cuda [Re: johngeery] #1905196
09/02/15 07:30 PM
09/02/15 07:30 PM
kansas
kansas
I was unable to get ahold of Bill, but I did find the two I was needing, now I just need to know:
does the flat bracket screw into the top of the console, or does it screw in underneath?
and about that plastic lip thingy....pn 3501124.
anybody have one?
Re: Console mount cassette player 71 cuda [Re: johngeery] #1905216
09/02/15 08:03 PM
09/02/15 08:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have one with original holes I can measure later.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1905228
09/02/15 08:23 PM
09/02/15 08:23 PM
kansas
kansas
thanks!
Re: Console mount cassette player 71 cuda [Re: johngeery] #1906613
09/05/15 12:01 AM
09/05/15 12:01 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
The flat plate goes under the console.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1910676
09/11/15 06:20 PM
09/11/15 06:20 PM
kansas
kansas
anyone know where exactly it screws to the console?
Re: Console mount cassette player 71 cuda [Re: johngeery] #1910756
09/11/15 09:49 PM
09/11/15 09:49 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
You have to line it up yourself unless someone can provide measurements, I've seen consoles @ swap meets that had the holes in them maybe someone has one that they could check for you.
Re: Console mount cassette player 71 cuda [Re: johngeery] #1910782
09/11/15 10:40 PM
09/11/15 10:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Do these help? FYI, this one is original and I've seen multiples, no two have been exactly alike, location seems to have been a bit random and I've even seen multiple holes like they went in slightly off and were then moved and drilled again to correct it. And yes, there were only 4 screws in this one!
Re: Console mount cassette player 71 cuda [Re: johngeery] #1910783
09/11/15 10:40 PM
09/11/15 10:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Couple more
