Front shock recommendation a body #1898141
08/24/15 02:55 AM
08/24/15 02:55 AM
fresno ca
mikeysmopars Offline OP
fresno ca
Lookin to upgrade my front shocks on my dart.
Currently has Calvert 90/10s and the front shakes pretty hard when it hits. Car weighs 3150 with me and need to fit stock location. I know they say buy the best but what is a good shock for the money? Car only runs 10.0s so I don't want overkill, appreciate your input!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Front shock recommendation a body [Re: mikeysmopars] #1898160
08/24/15 04:09 AM
08/24/15 04:09 AM
Koni SPAs, if you can find a set still up I had them on my Duster, way better than the more expensive QUA-1 twocents
Re: Front shock recommendation a body [Re: mikeysmopars] #1898162
08/24/15 04:28 AM
08/24/15 04:28 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm running the el cheapo Comp Eng 3 way adjustables. i did upgrade? to a set of Koni's but found the CE's gave me better 60 fts. so much for the upgrade. i run low 9's with long wheels stands & no shake with these junkers.
Re: Front shock recommendation a body [Re: mikeysmopars] #1898199
08/24/15 10:24 AM
08/24/15 10:24 AM
an8sec70cuda Offline
Vikings.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Front shock recommendation a body [Re: mikeysmopars] #1898211
08/24/15 10:48 AM
08/24/15 10:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Afco's double adjustable, love mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Front shock recommendation a body [Re: mikeysmopars] #1898333
08/24/15 02:33 PM
08/24/15 02:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Strange
Re: Front shock recommendation a body [Re: mikeysmopars] #1898405
08/24/15 03:55 PM
08/24/15 03:55 PM
Locomotion Online content
Locomotion  Online Content
Koni SPA-1s worked great on my car but they had to be removed to adjust. Changing track conditions make easy adjustability very useful. I have QA-1 single adjustables on the front now alternating between 3 & 4, with "full soft" as "0". But I went with an "experimental" set of double-adjustable Viking shocks for the front of my Volare project. The QA-1 are pre-set pretty stiff on compression, which works well, but the Vikings can be fine tuned.
My current car 60 foot times vary between 1.46 and 1.51 @ 3,540 lbs +, depending on weather and if it's on "kill" or bracket mode. But I plan to stick with Viking if and when I need shocks again. I like their customer service.
Re: Front shock recommendation a body [Re: mikeysmopars] #1898411
08/24/15 04:04 PM
08/24/15 04:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Buy the best shock you are willing to pay for.
If you are wanting somebody to tell you that so and so $100 shocks, perform just as well as so and so $300 shocks.........well, that simply isn't going to be true. So again, buy best shock you are willing to pay for.
Re: Front shock recommendation a body [Re: mikeysmopars] #1898487
08/24/15 05:43 PM
08/24/15 05:43 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I love my $180 Viking shocks!
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Front shock recommendation a body [Re: an8sec70cuda] #1898823
08/25/15 02:18 AM
08/25/15 02:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Vikings all the way around now,,,,,,,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Front shock recommendation a body [Re: mikeysmopars] #1898899
08/25/15 09:12 AM
08/25/15 09:12 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Do any of you guys have a viking part number for the fronts and rears?
It would be appreciated
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Front shock recommendation a body [Re: hemi-itis] #1898907
08/25/15 09:53 AM
08/25/15 09:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You run yours yet?
Re: Front shock recommendation a body [Re: turbo toad] #1898913
08/25/15 10:15 AM
08/25/15 10:15 AM
http://www.vi-king.com/
If you need custom valving, call and ask them.
CHIP
Re: Front shock recommendation a body [Re: mikeysmopars] #1898935
08/25/15 10:59 AM
08/25/15 10:59 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just got viking rears for my car. While i haven't used them yet they have been great to deal with via email. One of my shocks showed up without any bushings in it and the return and exchange went real smooth. I hope to be testing them out this friday.
68 Barracuda Formula S 340
Re: Front shock recommendation a body [Re: mikeysmopars] #1898963
08/25/15 12:17 PM
08/25/15 12:17 PM
Dave_S Offline
Dave_S  Offline
1.21 60 ft!
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Front shock recommendation a body [Re: mikeysmopars] #1899007
08/25/15 01:12 PM
08/25/15 01:12 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I run strange singles and viking doubles on my scamp...The single adjustable up front helped big time with getting the car to hook on a radial- the car actually 60'd best with the front shocks at 4 clicks away from full loose, which goes to show what I have heard many say over the years- the faster the car the less you need a "full loose" shock and one that has the ability to actually control front end rise.
If I had to buy again it would be Viking or Afco....Not a fan of Strange products or their customer service
Re: Front shock recommendation a body [Re: mshred] #1899019
08/25/15 01:20 PM
08/25/15 01:20 PM
Dyno1 Offline
Dyno1  Offline
I would buy Afco. The QA! and Viking shocks are throw away if you want to rebuild them. Call Randy at Fastshocks. He is a dealer and rebuilder. He has helped many of the top sportsman racers around the country. 612-306-5387
Re: Front shock recommendation a body [Re: mikeysmopars] #1899110
08/25/15 03:24 PM
08/25/15 03:24 PM
Dave_S Offline
Dave_S  Offline
vikings are fully rebuildable and re-valveable
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Front shock recommendation a body [Re: mikeysmopars] #1899206
08/25/15 05:24 PM
08/25/15 05:24 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Your front end shake is not likely shock related but geometry related.
From your pic the front end is up in the air and the upper a arm has a lot of drop is there a stop on the arm ? the more drop the more toe out.
i also had to make the tie rod sleeve longer ( heat and bend lower ball joint closer to the tire) to lesson toe out change.
the more mph when landing the more critical.
Re: Front shock recommendation a body [Re: mikeysmopars] #1899276
08/25/15 07:31 PM
08/25/15 07:31 PM
fresno ca
fresno ca
Here is a pic with it off the ground, I had the alignment done with typical zero degree toe and about 7 degree caster rocked in it.
All suspension parts are new and even had the box rebuilt. As far as acromion and bump steer I do not know but several people that has watched the car said shocks as well as folks on this forum. I'm just going to start eliminating suspects.
