c-body control arms #1898360
08/24/15 03:13 PM
08/24/15 03:13 PM
germany
P
paddel Offline OP
paddel  Offline OP
P
germany
are there any aftermarket upper control arms for my 74 newport that are a little bit more reliable?
The ones i found (aftermarket and original) are for b and e bodies.
Re: c-body control arms [Re: paddel] #1898366
08/24/15 03:16 PM
08/24/15 03:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
None that I know of.
I doubt seriously you will find them. The cars have very little interest (in the big picture) and only a fraction of those people with interest will actually spend money on them.
- Stu Harmon
Re: c-body control arms [Re: paddel] #1898422
08/24/15 04:17 PM
08/24/15 04:17 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
In what regard? Stockers are pretty good. are you looking for more alignment adjustability?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: c-body control arms [Re: paddel] #1898440
08/24/15 04:36 PM
08/24/15 04:36 PM
AndyF Offline
AndyF  Offline
Firm Feel can build them for you if you really, really want them.
Re: c-body control arms [Re: paddel] #1898501
08/24/15 06:00 PM
08/24/15 06:00 PM
germany
P
paddel Offline OP
paddel  Offline OP
P
germany
mine broke on the left side so I thought aftermarket would be better. But even originals are hard to find for me. the scrapyards in the US won't ship to germany and then the part is still used and may break as well.
Re: c-body control arms [Re: paddel] #1898503
08/24/15 06:07 PM
08/24/15 06:07 PM
germany
P
paddel Offline OP
paddel  Offline OP
P
germany
the firm feel ones are for c-bodies from 65-73. mine is 74
Re: c-body control arms [Re: paddel] #1898522
08/24/15 06:50 PM
08/24/15 06:50 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
40 years of service isn't reliable enough? work
Control arms normally don't 'just' break.
Why not repairing/welding the one you have?
Re: c-body control arms [Re: paddel] #1898537
08/24/15 07:09 PM
08/24/15 07:09 PM
germany
P
paddel Offline OP
paddel  Offline OP
P
germany
I would but the ball joint broke loose. The whole thread is gone. also the thread walls broke away. There is no way to repair it.
I now welded the ball joint into the control arm.
About the 40 years of service. It would apply if I could get a new one. But as I said, I only can get used ones.
That's why I asked.
Re: c-body control arms [Re: BigBlockMopar] #1898606
08/24/15 09:11 PM
08/24/15 09:11 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
try at www forcbodiesonly dot com
Re: c-body control arms [Re: paddel] #1898626
08/24/15 09:31 PM
08/24/15 09:31 PM
Tacoma, Washington USA
Adam71Charger Offline
If you decide you want a used control arm, Look on American Craigslist (in high population areas like Portland, New york, Seattle Etc etc) and look for cheap 74 or 75 newport's/new yorker's that are being parted out, and see if they'll sell you what you need. Control arms usually dont go bad even when the rest of the car is a rusted out pile of crap. its usually the body and interior that get the worst of it
Re: c-body control arms [Re: paddel] #1899059
08/25/15 02:21 PM
08/25/15 02:21 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Aren't half ton 2 wd truck arms the same? Or maybe vans? I know there's some interchangeable parts among the 3.
Angry white pureblood male
Re: c-body control arms [Re: paddel] #1899088
08/25/15 02:59 PM
08/25/15 02:59 PM
AndyF Offline
AndyF  Offline
Wildcat probably has control arms. They have most everything in their yard.
Re: c-body control arms [Re: paddel] #1899151
08/25/15 04:02 PM
08/25/15 04:02 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I agree with that. failure of that part isn't common. I would try to grab up a used one
Re: c-body control arms [Re: paddel] #1899577
08/26/15 03:13 AM
08/26/15 03:13 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If it uses a threaded ball joint, you can buy a threaded sleeve to repair the arm you have.
http://www.speedwaymotors.com/Steel-Upper-Ball-Joint-Sleeve-K772-Style,2126.html
Kevin
