Best way to prep a intake for painting #1897814
08/23/15 06:28 PM
08/23/15 06:28 PM
69x Offline OP
69x  Offline OP
I have the carb off my car for a rebuild so I was wondering the best way to prep the intake before I paint it ?
I am not taking it off the motor, I plan to repaint with it on, it needs it as the old paint is very discolored, Thanks guys.
Re: Best way to prep a intake for painting [Re: 69x] #1897933
08/23/15 09:58 PM
08/23/15 09:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Mask the carb opening real good.
Remove any obvious grease and dirt with simple green, etc.
Scotch brite pad any loose paint off until you have a solid substrate.
Clean again and again with wax and grease remover until you know it's clean.
Mask everything you don't want paint overspray on.
If you have a shop vac you can place the hose near where your painting and it will vacuum up any overspray floating in the air.
Any hard to reach spots can be lightly painted with a brush first and then painted over with the aerosol can or paint gun.
Re: Best way to prep a intake for painting [Re: 69x] #1897936
08/23/15 10:02 PM
08/23/15 10:02 PM
I'd clean it squeaky clean with wax & grease remover then scuff it with steel wool of the right grade & (final) clean it again) with WG remover. covering close in/hard to reach areas with vaseline to avoid overspray. some places just cant be taped off
Re: Best way to prep a intake for painting [Re: RapidRobert] #1898063
08/24/15 12:20 AM
08/24/15 12:20 AM
69x Offline OP
69x  Offline OP
Thanks, one more question, would you spay it with one coat of paint or more and how much time in between ?
Re: Best way to prep a intake for painting [Re: 69x] #1898086
08/24/15 12:42 AM
08/24/15 12:42 AM
I ain't a painter but I've always believed that several lighter coats is much better & even the rattle cans tell you how long to wait between coats, that the coat has to "flash" dry. Problem I always had was debris settling on the surface in between coats. But wait for more experienced input
Re: Best way to prep a intake for painting [Re: 69x] #1898144
08/24/15 03:01 AM
08/24/15 03:01 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
I would etch primer after cleaning it.
Re: Best way to prep a intake for painting [Re: 69x] #1898280
08/24/15 12:58 PM
08/24/15 12:58 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Depending on the brand of paint, Rustoleum for example has a window for recoating. Couple hours iirc. If you try to recoat after that it wrinkles up unless you wait the 2 or 3 days (iirc) if you miss the 2 hour window. Bottom line, read product direction carefully up
Scott
