Re: Best way to prep a intake for painting
[Re: 69x]
#1897936
08/23/15 10:02 PM
08/23/15 10:02 PM
RapidRobert
I'd clean it squeaky clean with wax & grease remover then scuff it with steel wool of the right grade & (final) clean it again) with WG remover. covering close in/hard to reach areas with vaseline to avoid overspray. some places just cant be taped off
[Re: 69x]
#1898086
08/24/15 12:42 AM
08/24/15 12:42 AM
RapidRobert
I ain't a painter but I've always believed that several lighter coats is much better & even the rattle cans tell you how long to wait between coats, that the coat has to "flash" dry. Problem I always had was debris settling on the surface in between coats. But wait for more experienced input
