Front shock recommendation a body
#1898141
08/24/15 02:55 AM
08/24/15 02:55 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Lookin to upgrade my front shocks on my dart. Currently has Calvert 90/10s and the front shakes pretty hard when it hits. Car weighs 3150 with me and need to fit stock location. I know they say buy the best but what is a good shock for the money? Car only runs 10.0s so I don't want overkill, appreciate your input!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Front shock recommendation a body
[Re: mikeysmopars]
#1898162
08/24/15 04:28 AM
08/24/15 04:28 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i'm running the el cheapo Comp Eng 3 way adjustables. i did upgrade? to a set of Koni's but found the CE's gave me better 60 fts. so much for the upgrade. i run low 9's with long wheels stands & no shake with these junkers.
[Re: mikeysmopars]
#1898199
08/24/15 10:24 AM
08/24/15 10:24 AM
Posts: 13,398 Marion, South Carolina [><]
an8sec70cuda
[Re: mikeysmopars]
#1898211
08/24/15 10:48 AM
08/24/15 10:48 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Afco's double adjustable, love mine.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: mikeysmopars]
#1898405
08/24/15 03:55 PM
08/24/15 03:55 PM
Posts: 5,895 Florida
Locomotion
Koni SPA-1s worked great on my car but they had to be removed to adjust. Changing track conditions make easy adjustability very useful. I have QA-1 single adjustables on the front now alternating between 3 & 4, with "full soft" as "0". But I went with an "experimental" set of double-adjustable Viking shocks for the front of my Volare project. The QA-1 are pre-set pretty stiff on compression, which works well, but the Vikings can be fine tuned.
My current car 60 foot times vary between 1.46 and 1.51 @ 3,540 lbs +, depending on weather and if it's on "kill" or bracket mode. But I plan to stick with Viking if and when I need shocks again. I like their customer service.
[Re: mikeysmopars]
#1898411
08/24/15 04:04 PM
08/24/15 04:04 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Buy the best shock you are willing to pay for.
If you are wanting somebody to tell you that so and so $100 shocks, perform just as well as so and so $300 shocks.........well, that simply isn't going to be true. So again, buy best shock you are willing to pay for.
[Re: an8sec70cuda]
#1898823
08/25/15 02:18 AM
08/25/15 02:18 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Vikings all the way around now,,,,,,,,,,,,
[Re: mikeysmopars]
#1898899
08/25/15 09:12 AM
08/25/15 09:12 AM
Posts: 368 michigan
turbo toad
michigan
Do any of you guys have a viking part number for the fronts and rears? It would be appreciated
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: hemi-itis]
#1898907
08/25/15 09:53 AM
08/25/15 09:53 AM
1967dartgt
Hilltown Pa
Vikings all the way around now,,,,,,,,,,,, You run yours yet?
[Re: turbo toad]
#1898913
08/25/15 10:15 AM
08/25/15 10:15 AM
an8sec70cuda
Do any of you guys have a viking part number for the fronts and rears? It would be appreciated http://www.vi-king.com/ If you need custom valving, call and ask them.
[Re: mikeysmopars]
#1898935
08/25/15 10:59 AM
08/25/15 10:59 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I just got viking rears for my car. While i haven't used them yet they have been great to deal with via email. One of my shocks showed up without any bushings in it and the return and exchange went real smooth. I hope to be testing them out this friday.
68 Barracuda Formula S 340
[Re: mikeysmopars]
#1899206
08/25/15 05:24 PM
08/25/15 05:24 PM
Posts: 103 muskegon MI
v cummins
muskegon MI
Lookin to upgrade my front shocks on my dart. Currently has Calvert 90/10s and the front shakes pretty hard when it hits. Car weighs 3150 with me and need to fit stock location. I know they say buy the best but what is a good shock for the money? Car only runs 10.0s so I don't want overkill, appreciate your input! Your front end shake is not likely shock related but geometry related. From your pic the front end is up in the air and the upper a arm has a lot of drop is there a stop on the arm ? the more drop the more toe out. i also had to make the tie rod sleeve longer ( heat and bend lower ball joint closer to the tire) to lesson toe out change. the more mph when landing the more critical.
[Re: mikeysmopars]
#1899276
08/25/15 07:31 PM
08/25/15 07:31 PM
mikeysmopars
fresno ca
Here is a pic with it off the ground, I had the alignment done with typical zero degree toe and about 7 degree caster rocked in it. All suspension parts are new and even had the box rebuilt. As far as acromion and bump steer I do not know but several people that has watched the car said shocks as well as folks on this forum. I'm just going to start eliminating suspects.
