Re: 98 Ram no start
[Re: 318Bruiser]
#1897947
08/23/15 10:17 PM
08/23/15 10:17 PM
Posts: 5,884 ohio
ruderunner
ohio
Pics of what you're seeing? Doesn't sound stock.
Angry white pureblood male
Re: 98 Ram no start
[Re: 318Bruiser]
#1899569
08/26/15 02:39 AM
08/26/15 02:39 AM
Posts: 859 Southeast Pa.
SALEM1912
Southeast Pa.
Asd feed supply. If you have voltage at the fuse then you have a bad PDC. If so pull it up and figure how you can wire from fuse to the #30 terminal of the relay.
Re: 98 Ram no start
[Re: 318Bruiser]
#1899763
08/26/15 02:35 PM
08/26/15 02:35 PM
SALEM1912
Southeast Pa.
Are you saying the fuse is good? If yes ck the thermial that the fuse goes into to see if it is spread and not making contrat. For testing yes,but for a proper repair it's best tto find the problem. ASD relay drives a lot of things.
Re: 98 Ram no start
[Re: 318Bruiser]
#1899782
08/26/15 03:05 PM
08/26/15 03:05 PM
Posts: 396 Iowa
318Bruiser
Iowa
The 30A fuse has power to it but not to the asd. That is why I thought maybe just putting an inline fuse from another power wire to the ASD would work.
