A 'Quench' Question for the Engine Builders Here. #189703
01/10/09 05:54 PM
01/10/09 05:54 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I'm currently building a 440 street motor for my sig car and need opinions on my quench distance. I'm using aluminum heads with a true static CR of 10.0 to 1. I am having the block decked to where the pistons are .005 below deck. Figuring a compressed gasket thickness of .039 this would give me a 'quench' distance of .044 . The head gaskets I was planning on using were the ROL Hi-Temps as they have a 4.50 diameter and that is about the minimum I need for my 440 source head chambers. The problem is the ROL's are spec'd at .045 compressed thickness which would give me a quench distance of .050 . Is this going to be a problem with 92 oct pump gas? Thanks
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189704
01/10/09 05:58 PM
01/10/09 05:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
At only 10:1 with aluminum Stealths, you shouldn't have any issues.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: A 'Quench' Question for the Engine Builders Here. [Re: Triple Threat] #189705
01/10/09 06:11 PM
01/10/09 06:11 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I have used FelPro 1009 on Stealth heads (4.350 bore) with no issues.
In fact re-used them 2X.
Re: A 'Quench' Question for the Engine Builders Here. [Re: AAR-B4] #189706
01/10/09 06:24 PM
01/10/09 06:24 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
You'll be fine with those
Re: A 'Quench' Question for the Engine Builders Here. [Re: wyoming] #189707
01/10/09 06:28 PM
01/10/09 06:28 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Generally the accepted minimum useful quench is .050", so you should be ok.
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189708
01/10/09 06:29 PM
01/10/09 06:29 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
My pistons are .015" below deck so I used .027" Cometic head gaskets, that gives me .042" quench. A little overhang won't hurt with this type of gasket and they are available in a number of compressed thicknesses, and diameter.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: A 'Quench' Question for the Engine Builders Here. [Re: dizuster] #189709
01/10/09 06:32 PM
01/10/09 06:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It's alot closer to max than it is to minimum...
Run the Felpro 1009.. If your concerned hold it up to your head if it doesn't overhang the chamber (it won't )run it..
Re: A 'Quench' Question for the Engine Builders Here. [Re: 1_WILD_RT] #189710
01/10/09 08:55 PM
01/10/09 08:55 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks for the replys so far. Is the FelPro 1009 at 4.350 the largest diameter .039 thickness gasket available without going 'exotic' ie custom? Also, my block hasn't been decked yet so I could go .000 but i'm not sure that's the way to go.
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189711
01/10/09 08:59 PM
01/10/09 08:59 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
The 1009 has a 4.410 dia.
I mentioned the cylinder bore because of the overhang issue.
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189712
01/10/09 09:00 PM
01/10/09 09:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Block isn't decked yet..Have you assembled/mocked up the short block to verify deck height? Cause typically the piston that should be .005 in the hole actually measures .015-.025 in the hole...
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189713
01/10/09 09:23 PM
01/10/09 09:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Felpro 8519 PTI has a bore size of about 4.52 @ a .038 or so compressed thickness. It should be More then plenty for your 10.1 comp. They used to be cheap, dont know what they are now.
They used to come standard in the engine tear down gasket kits from MP. Still available from Summit pt# DCC3690175 for $65.95
This kit gives you every gasket that you could need, including the intake pan gasket. The head gasket themselves can be bought at Autozone or Advanced auto. mike
Re: A 'Quench' Question for the Engine Builders Here. [Re: Sport440] #189714
01/10/09 09:37 PM
01/10/09 09:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If the block has not yet been decked, why would you tell them to deck it to .005 below? If anything I'd tell them to go to .005 above with the knowledge that I'd be lucky if the final result didn't turn out to be a zero deck or below.
Re: A 'Quench' Question for the Engine Builders Here. [Re: DaytonaTurbo] #189715
01/10/09 09:46 PM
01/10/09 09:46 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, when I measured my piston to deck height the 'four corners' averaged .018 to .020 below deck. I've read that .035 or so is the minimum piston to head clearance. I've also read that around .040 to .045 is the ideal quench distance. I'm not a math major but where I went to school .005 deck clearnce + .039 gasket thickness = .044 piston to deck/quench distance. This is why I'm soliciting input.
Re: A 'Quench' Question for the Engine Builders Here. [Re: Classof70Chally] #189716
01/10/09 10:06 PM
01/10/09 10:06 PM
Las Vegas NV
moparmanjames Online content
moparmanjames  Online Content
Las Vegas NV
Just have it zero decked and use the fel-pro gasket, you are already taking .015 off, whats another .005?
Just don't forget you might have to mill the intake as well.
Re: A 'Quench' Question for the Engine Builders Here. [Re: moparmanjames] #189717
01/10/09 11:17 PM
01/10/09 11:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well IMO heres why you won't have to cut the intake...The original steel shim head gasket is .021 the Felpro is .039 thats .018 difference if you cut .015-.020 off the deck in reality the heads are in the same place they started...
BTW lots of guys say there are definate gains keeping the quench under .040 but definately shoot for less than .050 cause if you shoot for .050 & a few #s are not quite what they should be...Like it or not it happens...Then you'll have no effective quench..
Re: A 'Quench' Question for the Engine Builders Here. [Re: 1_WILD_RT] #189718
01/10/09 11:40 PM
01/10/09 11:40 PM
Las Vegas NV
Las Vegas NV
Good point with the head gaskets and in theory you are right on but in general with all the aftermarket heads and intakes, more often than not you end up with extra machining required.
As far as the quench, also keep in mind that on the other end of the spectrum .035 is the absolute minimum for a street car. So be careful when erring on the close side.
Re: A 'Quench' Question for the Engine Builders Here. [Re: moparmanjames] #189719
01/11/09 12:28 AM
01/11/09 12:28 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
didnt the chyrsler manual say no closer than .060
Mopar Performance
Re: A 'Quench' Question for the Engine Builders Here. [Re: moparniac] #189720
01/11/09 12:39 AM
01/11/09 12:39 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You believe everything you read???
Even if you don't..Read this..
http://racingsecrets.com/article_racing-10.html
Re: A 'Quench' Question for the Engine Builders Here. [Re: moparniac] #189721
01/11/09 10:58 AM
01/11/09 10:58 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Maybe in the day's of sloppy pistons, but not the way stuff is tightly controlled today.
I just put a 416" stroker motor together, and it was between .030"~.035" with no problems...
Re: A 'Quench' Question for the Engine Builders Here. [Re: 1_WILD_RT] #189722
01/11/09 02:10 PM
01/11/09 02:10 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Missed this one on my first read thru. Yes, I mocked up the short block using the same piston and rod at each of the four corner holes per my machinists instructions. The measurements were very consistent with the piston between .018 and .020 below deck. It sounds like I need to have .020 taken off the decks for something closer to 'zero' deck height. That way if I run the FelPro (.039) or the ROL (.045) I'm covered. I was trying not to get too close to the minimum .035 piston to head clearance but with steel rods and a max rpm limit of 5,800 to 6,000 maybe I'll be OK ?
