Re: A 'Quench' Question for the Engine Builders Here.
[Re: Classof70Chally]
#189708
01/10/09 06:29 PM
01/10/09 06:29 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
My pistons are .015" below deck so I used .027" Cometic head gaskets, that gives me .042" quench. A little overhang won't hurt with this type of gasket and they are available in a number of compressed thicknesses, and diameter.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: dizuster]
#189709
01/10/09 06:32 PM
01/10/09 06:32 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Generally the accepted minimum useful quench is .050", so you should be ok.
It's alot closer to max than it is to minimum...
Run the Felpro 1009.. If your concerned hold it up to your head if it doesn't overhang the chamber (it won't )run it..
[Re: moparmanjames]
#189717
01/10/09 11:17 PM
01/10/09 11:17 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Just have it zero decked and use the fel-pro gasket, you are already taking .015 off, whats another .005?
Just don't forget you might have to mill the intake as well.
Well IMO heres why you won't have to cut the intake...The original steel shim head gasket is .021 the Felpro is .039 thats .018 difference if you cut .015-.020 off the deck in reality the heads are in the same place they started...
BTW lots of guys say there are definate gains keeping the quench under .040 but definately shoot for less than .050 cause if you shoot for .050 & a few #s are not quite what they should be...Like it or not it happens...Then you'll have no effective quench..
[Re: 1_WILD_RT]
#189718
01/10/09 11:40 PM
01/10/09 11:40 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Good point with the head gaskets and in theory you are right on but in general with all the aftermarket heads and intakes, more often than not you end up with extra machining required. As far as the quench, also keep in mind that on the other end of the spectrum .035 is the absolute minimum for a street car. So be careful when erring on the close side.
[Re: moparniac]
#189721
01/11/09 10:58 AM
01/11/09 10:58 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
didnt the chyrsler manual say no closer than .060
Maybe in the day's of sloppy pistons, but not the way stuff is tightly controlled today.
I just put a 416" stroker motor together, and it was between .030"~.035" with no problems...
