528 mopar cam vaccum / valve lash ??? #1895078
08/19/15 01:47 AM
08/19/15 01:47 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
would like to here from persons that have one in use !
will the 528 cam make enough vac to properly operate power brakes ??
what valve lash with ALU heads ?
thank you !
Re: 528 mopar cam vaccum / valve lash ??? [Re: calrobb2000] #1895248
08/19/15 11:40 AM
08/19/15 11:40 AM
Canada north shore lake Ontari...
ross Offline
ross  Offline
I have run this cam for years. Cannot help with Vac as I use manual brakes. I set my lash at 022 cold Int and 26 cold Exh . I run Eddy RPM heads .
Re: 528 mopar cam vaccum / valve lash ??? [Re: calrobb2000] #1895710
08/20/15 12:50 AM
08/20/15 12:50 AM
s. e. pa.
s. e. pa.
only 1 person running this cam???
Re: 528 mopar cam vaccum / valve lash ??? [Re: calrobb2000] #1895819
08/20/15 10:43 AM
08/20/15 10:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That is a good street cam. It pulls a ton of vacuum so don't worry about power brakes. I set mine up a little tighter than factory... .022/.026 cold. It seems to run better for me at that lash than the factory setting. (iron headed 440-6)
Re: 528 mopar cam vaccum / valve lash ??? [Re: calrobb2000] #1895820
08/20/15 10:52 AM
08/20/15 10:52 AM
AndyF Offline
AndyF  Offline
Tech Archives: http://www.moparts.org/Tech/Archive/bb/Lobe.html
Re: 528 mopar cam vaccum / valve lash ??? [Re: calrobb2000] #1895835
08/20/15 11:21 AM
08/20/15 11:21 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
This has been discussed MANY times, the search function works well. twocents
Re: 528 mopar cam vaccum / valve lash ??? [Re: Mr.Yuck] #1895879
08/20/15 01:01 PM
08/20/15 01:01 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Are you still running that cam? I thought you got a custom ground solid
