Lokar anchor tight locking dipstick is there room??? #1894745
08/18/15 08:39 PM
08/18/15 08:39 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Is there room to put one of these on My 68 GTX B Body?? Buddy tried to put one on his 67 plymouth B body and said there is no room and it broke off. It sure seems to be a needlessly long bottom part for no reason and way up and out from tranny no good reason?? any help and thoughts would be appreciated.
http://www.summitracing.com/int/parts/lok-1211444
Says firewall mount Plymouth Dodge Chrysler but thats it??
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1894758
08/18/15 08:53 PM
08/18/15 08:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt use the stanchion on my 518 BUT they
didnt make a locking one from Locar that would
work right... I cut the locking end off the one
that locks(like that stanchion one) and cut mine
and welded it on... you cant even see it was done..
I'll get a pic tomorrow of it
wave
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1894991
08/19/15 12:17 AM
08/19/15 12:17 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had to massage the tunnel of my pickup to get clearance for mine with a small block 727. I would imagine a B body is even tighter than a truck.
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895012
08/19/15 12:37 AM
08/19/15 12:37 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Yea thanks picture would be nice to see. thanks guys
Re: Lokar anchor tight locking dipstick is there room??? [Re: slantzilla] #1895069
08/19/15 01:33 AM
08/19/15 01:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the shield on there also... its tight but I
made the tunnel to just clear.. the bends were tight
enough that I had to cut 1/2 of the end of the stick
(just below the full mark a 1/4")so the stick could
make the turns.... I'll get a pic tomorrow
EDIT
Mine is a cable going down... I assume is also
wave
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895198
08/19/15 10:12 AM
08/19/15 10:12 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Yes cable don't know why that piece has to be 6 inches instead of like 2"
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895210
08/19/15 10:36 AM
08/19/15 10:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The housing on mine goes right into the trans housing
then up and over the shield and just on the front side
of the mid plate then mounts to the firewall... I dont
use that tall part at the trans
EDIT
I even spun up a adapter to plug in the to the locking
part just so it is easier to fill.. hooks up to the
hose on my funnel
wave
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895498
08/19/15 06:16 PM
08/19/15 06:16 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Going to skip it for now and see if I can have that tall part at trans shortened or find a short adapter for the tanny. Thanks thick I'll call Lokar no need at all for that 6 inch high piece a 2" would be much better for a full bodied car??
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895525
08/19/15 06:59 PM
08/19/15 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is how I made a locking one..they said there
wasnt any.... you can see where I made the change
right at the bracket mount
EDIT
You can see the one pic is locked the other is open
wave
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1895653
08/19/15 10:52 PM
08/19/15 10:52 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
Go to Mastaperformance.com He may have or be able to make something work.. Mopar guy forever, That is all he does is build dipsticks. I have them on my car.. Not sure if I have a pic of the trans one but if you look close engine one is here. Kevin
71 gtx.....
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1897950
08/23/15 10:20 PM
08/23/15 10:20 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I tried one of those on my 69 GTX,no way it would work,hit the trans tunnel.
Re: Lokar anchor tight locking dipstick is there room??? [Re: bonefish] #1897970
08/23/15 10:42 PM
08/23/15 10:42 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Heres what I used. Its from Mancini....http://ep.yimg.com/ay/chucker54/mancini-racing-locking-transmission-dipstick-70.gif
Part # MRE676
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Lokar anchor tight locking dipstick is there room??? [Re: Dodgem] #1898011
08/23/15 11:26 PM
08/23/15 11:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I modified the stock tube. Cut the mounting bracket off. Fab a new bracket that has the mounting hole 90 degrees to the original. The new tab will now attach to the boss with the hole on the trans bell housing. It will be much easier to install and remove. You can also rotate it in the trans for the most clearance before you weld the tab. Go to the junkyard and get a GM trans dip stick. Remove the roll pins at the top to remove the locking mechanism. Trim your Mopar dipstick .050" on each side at the top so the GM locking mechanism slides over it. You may have to trim the length slightly so it registers correctly, make a trial fit. Drill 2 holes where the roll pins went through the Mopar stick. Attach the locking mechanism with 6/32 screws and a dab of locktite to the Mopar stick. $5 at the junkyard and 15 minutes work.
Doug
Re: Lokar anchor tight locking dipstick is there room??? [Re: bonefish] #1898442
08/24/15 04:40 PM
08/24/15 04:40 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
LOL thanks never put it on engine goes in in 15 minutes going to use my old lokar non locking for now.
